    Green Toaster's Car Sketches
    745 Posts 45 Posters 285.3k Views 45 Watching
    • MarianM
      Marian
      I can see you're improving.....you'll be making awesome cars in no time, not that the rest aren't.
      • G
        GreenToaster
        Thank you.
        Here's a very boring car . . . I think it could be salvaged by adding some details. I need to add mirrors, door handles, lights, part lines (hood, bumpers, et cetera) and then toss one into Kerkythera, although I've only done 2 super-simple renderings with KT so far.
        I realize my cars are very rough and that if I spent more time stitching surfaces they'd be smoother - that will come later.
        Happy sketching,
        Brad
        πŸ˜„
        If you really want something you won't ever stop pursuing it.
        • ely862meE
          ely862me
          at least looks like a real car,good job
          Elisei (sketchupper)
          Come and See EliseiDesign
          • G
            GreenToaster
            I'm creating a tutorial for this front end - I was almost done when I ran out of "undo".
            This front end literally takes 3 minutes, 4 with the scoop, & the tutorial might be useful for someone - it's super easy. The design is "flexible", meaning, if you set it up with layers, you can smush, stretch, pull, tug, rotate, move, et cetera, fairly easily for some decent "what if", on the fly design changes.
            BTW, does anyone know if there's a way to use the Drape tool without having to tilt the model vertical?
            Happy modeling,
            Brad
            πŸ˜„
            • G
              GreenToaster
              I posted a quick tutorial in the tutorial section . . . my tutorial isn't very good, but it might inspire someone to do something really cool . . . hope so.
              Happy modeling,
              Brad
              πŸ˜„
              • G
                GreenToaster
                . . . thought I'd revisit the 3-wheeler . . . need shock mounts on the body and some front end fairing stuff, tail lights, exhaust, door lines, & so forth, but, it's gettin' there . . .
                • G
                  GreenToaster
                  There's a crisis on the farm - I've gotta go do some work so no more cars for the rest of the week 😞 bummer!
                  Here are a couple of sketches I started this morning . . . see ya'll next week.
                  Happy Sketching,
                  Brad
                  πŸ˜„
                  • G
                    GreenToaster
                    I started this one a few days ago . . . it used the technique in the tutorial I posted earlier . . . this isn't really a good example - very bland car but I couldn't resist taking just a few minutes to almost finish it . . . it's ready for a rear end, and detailing . . . I have some more ideas I've sketched up (on pencil & paper) . . . hopefully, I'll be able to model them accurately in the next few days using SketchUp . . . what else?
                    Happy modeling,
                    Brad
                    πŸ˜„
                    • ely862meE
                      ely862me
                      from my oppinion this is the best
                      • G
                        GreenToaster
                        I think I shortened the wheelbase a bit too much . . . I also need to rip out the windshield and add something smoother, no biggie . . . I think I'll take this one a bit further and add some details like mirrors, vents, lights, interior, the lines for doors, hood, et cetera, b/c I've never done that before and it should be a good learning experience.
                        Happy Sketching,
                        Brad
                        πŸ˜„
                          remus
                          you could jsut scale the whole thing to extend the wheelbase a bit...
                          • G
                            GreenToaster
                            Thanks for the suggestion - I built in a gap so it'd be silly easy to stretch it one way or the other . . . when working in Parallel Projection (side, top, whatever) you can select with precision quickly & easily, do the drag-n-drop, then it's done.
                            I've tried stretching large sections and get frustrated with oval or elliptical shapes inside the wheel wells . . . I've even made boo-boo's and ended up with oval tires & wheels - can you imagine riding in a car had oval tires? Bumpy, for sure.
                            Happy Sketching,
                            Brad
                              remus
                              forgot about the wheels πŸ‘Š
                                SchreiberBike
                                Bad news for you about that three wheeler.
                                It's got four wheels.
                                Re. scaling the model. If you make the wheels into a component first, then you can scale the rest of the model and leave the wheels round, or you could display all the geometry again and just select the part in front of and behind the wheel and scale and/or move that.
                                Here's what I came up with from your tutorial.
                                  remus
                                  i tihnk the problem is more to do with the wheel arches than the wheels.
                                  • G
                                    GreenToaster
                                    True (ha), but three axles.
                                    It's probably just me, but I find it challenging to model cars well - very fun, and I think I'm making a little progress (compared to the first posts I did here). I am much more confident in being able to create what I want - sketch out on paper, then model it.
                                    As I've said before, some folks can play the violin well in six weeks - for some, it takes a couple of years of practice to achieve the same level. I guess it's not important how slow I am at learning this stuff - I keep going and improving little by little - that's significant to me.
                                    If any of you haven't checked out the modeling videos and tutorials, there are some really good ones out there - YouTube, and several others, which I believe might be very helpful.
                                    Happy Sketching,
                                    Brad
                                    πŸ˜„
                                    • G
                                      GreenToaster
                                      . . . added a few more details . . . the panel editing is super-easy-fast . . . using scale in either direction, I select sections, or sub-sections & blah, blah, blah . . . (as with the tutorial I posted a day or so ago) . . .
                                      Happy Sketching,
                                      Brad
                                      πŸ˜„
                                        SchreiberBike
                                        When I was working on my hood above, I was amazed by how dull it looked because I knew I had put lots of clever angles into it. Adding the line for the space between the hood and the fender started to show the shape better. I also changed the color of the edge of the fender and of the A pillar to a reddish brown instead of bright red. I could have gone on and put some grooves in the hood to show more. Things like that bring out the geometry in SU, similarly to the way rendering would.
                                        • ely862meE
                                          ely862me
                                          the easyest way for rising the distance of weels is to rise just some segments in the midle of the car not to strech all the car
                                            Durant Hapke
                                            Brothers, and Sisters,
                                            Beauty -- this pop up batch of "cars" are all there and messing with me (in my head -- not in my hog barn -- not in my exhaust vector).
                                            You blazing batch of SU perfecters ever hear that song "Jesus built my hot rod" by Ministry?
                                            It rules, and I trust that would make a grand soundtrack for this thread of four wheeled nights on the "battle field."
                                            I'm going to have to dig out that classic, crank the stereo to pain, pour a cold one, light a camel, and have my way with some of these images.
                                            Take it rough, and feel the art.
                                            I'm feeling mad cap power action on the horizon.
                                            Durant "Yeah baby, love is a battle field" Hapke
                                            • 11
                                            • 37
                                            • 38
                                            • 9 / 38
