    Problems with the new computer.
    46 Posts 9 Posters 4.2k Views 9 Watching
    • Alan FraserA Offline
      Alan Fraser
      We should rename this thread Mouse Tale.
      3D Figures
      • boofredlayB Offline
        boofredlay
        @solo said:
        Sounds good to me, I will be in Huntsville visiting in-laws and some outlaws this summer, maybe we can get a beer together.
        Sounds great, although I will be drinking tea. I gave up the booze almost 4 years ago and have not looked back. Although over the last couple days a cold one would have settled my nerves 😎
        Frederik, I am glad my pain has amused you πŸ˜† Just kidding.
        Alan, I think I can find a few good names for that mouse, or at least the software that came with it.
        Kind of ironic don't you think... I killed an entire mouse colony that settled into my garage this fall. πŸ˜•
        About nine mice in all.
          tomsdesk
          Ah...the dread intellipoint software bug again: you got off easy, my friend!
          2.5D Trees & Shrubs!
            boofredlay
            You warned me didn't you.
            Edit: Although as soon as I removed the software I left home and am now at work. I wonder if I will find any more glitches tonight.
              alpro
              Is it possible that some other software on Toms and Erics system is conflicting with intellipoint 6.1 and it's just showing up in SU? I have it installed, have different button setups for a few programs, and have never had a problem with SU or any other program. Hope I didn't just jinx myself. Anyway just a thought.
              Mike
                tomsdesk
                Mike...seems to be a conflict 6.1 and the newer forceware drivers: do you have an nvidia card?
                  boofredlay
                  Even though removing the mouse software fixed the problem?
                    boofredlay
                    I was not trying to be.
                    The thing is on my old machine and on my work machine I have the same mouse without the Intellipoint 6.1 software installed and don't have any problems.
                    I am not trying to argue I am trying to make sense of it.
                      boofredlay
                      Ok thanks Bruce. Sorry I misunderstood, I am a bit on edge today if you could not tell.
                        alpro
                        @Tom, this will probally piss some people off who just shelled out a few bucks for high end graphic cards. I have intergrated Nvidia graphics 6150SE nForce430 with 623mb total memory of which only 128mb is dedicated and am using the latest driver 169.25. At one point I was thinking of upgrading but I've never had a problem with any of my models because all are pretty small, also there was the column and crowd test skps floating around which I was able to fly through without any problems. So as the saying goes, if it ain't broke..... But the point being is that I am using the latest Nvidia driver and intellipoint.
                        Mike
                        • FrederikF Offline
                          Frederik
                          So.... It wasn't the mouse... 😲 πŸ˜•
                          Darn - it's getting better and better... It's really like following one of those TV series... πŸ˜†
                          Sad that this forum can't give a "sneak peak" of next episode... πŸ˜„
                          Cheers
                          Kim Frederik
                            tomsdesk
                            Mike, not to beat a dead horse...but are you using intellipoint 6.1 or 5.4? My search for a fix of my problems, similar to Eric's, found that there were PS and SF (Max too, I think I remember) problems with the newer but not the older mouse software.
                            Also, some of the problems with SU and Nvidia were fixed with the latest GeForce driver, not yet available for Quadro...?
                            Don't know who should fess up about all this, but losing the mouse driver is a quick fix (if you can get rid of it without reformating :`)
                            Side note (may make you feel less preggers, Eric): The files I was having major slowdown with that prompted me to upgrade are still slow as molassas on the new machine (may be corrupted afterall...?), and of course the smaller, or less complicated, files have no drain on the old machine...Murphy's Law (or less polite!)
                              boofredlay
                              Well if you look really carefully at Mike's post he does have 6.1
                              I just got off the phone with the guy who built my machine and he said I should never have installed the mouse driver. All I had to do was plug in the new mouse and restart... sometimes my ignorance is so strong 😒
                              Well to settle your mind a bit Tom the reason for the new machine is not specifically to have a new faster machine, we need 2 at the house as my wife is doing some online classes now.
                              And as for speed... as soon as I uninstalled the Intellipoint this morning I took a file that had a moderate amount of geometry and a pretty high res image copied 3 times in different orientations. I selected all of it and copied it 60 times and was able to navigate with only a tiny bit of slowdown. On the old machine, I would have seen smoke.
                                alpro
                                Tom, it is 6.1 and besides SU, no problems with PS CS3 Extended or Cadsoft Envisioneer, my other two mostly used programs.
                                Mike
                                  boofredlay
                                  Back home now and I turned Fast Feedback on again and no problems.
                                  Now all I have to do is get a new router.
                                  The one I am using now is a loaner from the company I got the computer from. So I still have to contact my ISP one more time and have them log the MAC address on a new router. I am just afraid to unplug anything right now 😐
                                  All in all if the company I got it from had given me the mouse I originally asked for, none of this would have happened, at least the visual issues. Now getting hooked up to the net was a completely different story.
                                    alpro
                                    Good to hear Eric.
                                    Mike
                                      boofredlay
                                      Ok, wish me luck. I have the new router and I am about to call my ISP. If you don't "hear" from me soon you will know I have hit critical mass. I don't forsee a problem however.
                                      Edit: The new router is installed and I am up and running. 😍
                                      Thank you all for your help and patience with me. πŸ˜‰ And Frederik, I am happy I could be your Peyton Place today πŸ˜†
                                      • 3 / 3
