    Problems with the new computer.
    46 Posts 9 Posters 6.2k Views 9 Watching
      alpro
      Is it possible that some other software on Toms and Erics system is conflicting with intellipoint 6.1 and it's just showing up in SU? I have it installed, have different button setups for a few programs, and have never had a problem with SU or any other program. Hope I didn't just jinx myself. Anyway just a thought.
      Mike
      • T
        tomsdesk
        Mike...seems to be a conflict 6.1 and the newer forceware drivers: do you have an nvidia card?
        2.5D Trees & Shrubs!
        • boofredlayB
          boofredlay
          Even though removing the mouse software fixed the problem?
          • boofredlayB
            boofredlay
            I was not trying to be.
            The thing is on my old machine and on my work machine I have the same mouse without the Intellipoint 6.1 software installed and don't have any problems.
            I am not trying to argue I am trying to make sense of it.
            • boofredlayB
              boofredlay
              Ok thanks Bruce. Sorry I misunderstood, I am a bit on edge today if you could not tell.
                alpro
                @Tom, this will probally piss some people off who just shelled out a few bucks for high end graphic cards. I have intergrated Nvidia graphics 6150SE nForce430 with 623mb total memory of which only 128mb is dedicated and am using the latest driver 169.25. At one point I was thinking of upgrading but I've never had a problem with any of my models because all are pretty small, also there was the column and crowd test skps floating around which I was able to fly through without any problems. So as the saying goes, if it ain't broke..... But the point being is that I am using the latest Nvidia driver and intellipoint.
                Mike
                • FrederikF
                  Frederik
                  So.... It wasn't the mouse... 😲 πŸ˜•
                  Darn - it's getting better and better... It's really like following one of those TV series... πŸ˜†
                  Sad that this forum can't give a "sneak peak" of next episode... πŸ˜„
                  Cheers
                  Kim Frederik
                  • T
                    tomsdesk
                    Mike, not to beat a dead horse...but are you using intellipoint 6.1 or 5.4? My search for a fix of my problems, similar to Eric's, found that there were PS and SF (Max too, I think I remember) problems with the newer but not the older mouse software.
                    Also, some of the problems with SU and Nvidia were fixed with the latest GeForce driver, not yet available for Quadro...?
                    Don't know who should fess up about all this, but losing the mouse driver is a quick fix (if you can get rid of it without reformating :`)
                    Side note (may make you feel less preggers, Eric): The files I was having major slowdown with that prompted me to upgrade are still slow as molassas on the new machine (may be corrupted afterall...?), and of course the smaller, or less complicated, files have no drain on the old machine...Murphy's Law (or less polite!)
                    • boofredlayB
                      boofredlay
                      Well if you look really carefully at Mike's post he does have 6.1
                      I just got off the phone with the guy who built my machine and he said I should never have installed the mouse driver. All I had to do was plug in the new mouse and restart... sometimes my ignorance is so strong 😒
                      Well to settle your mind a bit Tom the reason for the new machine is not specifically to have a new faster machine, we need 2 at the house as my wife is doing some online classes now.
                      And as for speed... as soon as I uninstalled the Intellipoint this morning I took a file that had a moderate amount of geometry and a pretty high res image copied 3 times in different orientations. I selected all of it and copied it 60 times and was able to navigate with only a tiny bit of slowdown. On the old machine, I would have seen smoke.
                        alpro
                        Tom, it is 6.1 and besides SU, no problems with PS CS3 Extended or Cadsoft Envisioneer, my other two mostly used programs.
                        Mike
                        • boofredlayB
                          boofredlay
                          Back home now and I turned Fast Feedback on again and no problems.
                          Now all I have to do is get a new router.
                          The one I am using now is a loaner from the company I got the computer from. So I still have to contact my ISP one more time and have them log the MAC address on a new router. I am just afraid to unplug anything right now 😐
                          All in all if the company I got it from had given me the mouse I originally asked for, none of this would have happened, at least the visual issues. Now getting hooked up to the net was a completely different story.
                            alpro
                            Good to hear Eric.
                            Mike
                            • boofredlayB
                              boofredlay
                              Ok, wish me luck. I have the new router and I am about to call my ISP. If you don't "hear" from me soon you will know I have hit critical mass. I don't forsee a problem however.
                              Edit: The new router is installed and I am up and running. 😍
                              Thank you all for your help and patience with me. πŸ˜‰ And Frederik, I am happy I could be your Peyton Place today πŸ˜†
                              • 3 / 3
