    Gif support
    16 Posts 5 Posters 5.5k Views 5 Watching
    • GaieusG
      Hm... Little trick I learnt here: rename (just rename) the gif extension to png and try that way... πŸ˜’
        remus
        im guessing that trick wouldnt work for gif animations gai?
        • GaieusG
          No, no animated gifs this way.
            Interesting.
            I've found that you don't even have to rename it. Since GIF and PNG file formats got different structures I got an idea;
            When you have the file dialogue window open, type in * in the filename textbox and hit the Enter key. Then all files will be listed and you can select and open your gif files.
            So it appears that GIF support already exists, it's just the file dialogue that lacks the listing for the file format.
            • GaieusG
              Hm... Even more interesting...
                So maybe this should be in the bug list instead?
                • GaieusG
                  As I remember GIF is not "officially" supported for some copyright reasons.
                    Gif used to be patented and had to be licensed. But the patent expired some years ago now and is free to use.
                      SpaceMan
                      But you can create animatation maker for SketchUp texture
                        remus
                        whats that spaceman? sounds interesting...
                          mpowell1234567890
                          @thomthom said:
                          Interesting.
                          How do I do it? I tried but see no animation..
                            @mpowell1234567890 said:
                            @thomthom said:
                            Interesting.
                            It only support static GIF images. No Animation. So it's actually a partial support of the GIF format.
                              mpowell1234567890
                              Can they add this feature to Sketchup 7 as a wishlist?
                              @thomthom said:
                              Interesting.
