    Have you ever seen one of these?
    19 Posts 12 Posters 2.9k Views 12 Watching
    • urgenU Offline
      urgen
      Originally and actually... It is really existing thing?
      --pupil forever...------
      • FrederikF Offline
        Frederik
        I have never seen one of these IRL... ๐Ÿ˜
        But I sure like the idea, although - and as you mention yourself - I'm not sure if the concept is conveniently possible...
        I can imagine that there would be issues with the soap remains from washing your hands in the toilet cistern... But what do I know... Maybe some kind of special soap or a filter would make this possible...?!? ๐Ÿ˜‰
        What render application have you used for the image..??
        Cheers
        Kim Frederik
        • Alan FraserA Offline
          Alan Fraser
          Interesting little spacesaver. There does actually seem to be a market for this kind of thing, but it's usually in stainless steel. http://www.acorneng.com/penal.htm
          3D Figures
            alpro
            @ urgen, yes they really exist, here's a link http://www.caroma.com.au/products/index_profile.html
            Someone on another forum I visit was looking for a model so I thought it was an interesting challenge.
            @ tomsdesk and Alan Fraser, I think that the stainless steel units are more commercial where as these are aimed at the residential market.
            @ Frederik, I wish that I could claim that as my rendering but it's a photo from their website ๐Ÿ˜† And my model doesn't look nearly as good ๐Ÿ˜ณ
            Mike
              bytor
              The one Alan references is for use in a correctional environment, as will likely be the case for any you find in stainless steel. In that setting (jails / prisons) they need to be as indestructable and tamper / vandalism proof as possible. In my experience - the water from the sink is not recycled for the toilet. The benefit of these type of units is saving space, and also the minimal number of fixed piping connections during construction, and when repairs need to be made. Also - they can be very refreshing on a cold morning! ๐Ÿ˜ฎ
              Edit.....spelling
              Find the Cost of Freedom.....
              • DanielD Offline
                Daniel
                I think it would also be useful in a design where the toilet and lavatory is compartmentalized or in separate rooms.
                My avatar is an anachronism.
                  Ampa
                  These are very common in Japan (where space is limited everywhere!). There is a slight inconvenience in that you have to straddle the toilet bowl (or kneel / stand on it - if you are short) but over all the design works well.
                  The soapy water does go into the cistern, but I'd imagine that it is watered down significantly since you don't use nearly as much water to wash your hands as it takes to fill the flush mechanism.
                  Ampa
                  • tinanneT Offline
                    tinanne
                    I must admit, it does seem practical.... but eeewwwwwwww! You wouldn't find me brushing my teeth in that! I know the water is not being sucked out of the toilet bowl, but just the thought of it grosses me out. ๐Ÿคข
                    Executive Director : American Society of Architectural Illustrators
                    AIP 30 Competition opens soon. ASAI.org
                    Architectural Rendering
                    • tinanneT Offline
                      tinanne
                      Alpro ๐Ÿ˜ณ I saw that and quickly deleted my post, sorry!
                      edit... PS, thank you for the component
                        alpro
                        tinanne, actually the skippy (component) is also attached above.
                        Mike
                        Edit
                        nevermind just saw that you removed your previous post.
                          alpro
                          That's ok. The model isn't that good, was basicially a challenge for myself. I was surprised at how hard it's to model a toilet bowl with all the curves. Maybe someone has a good method for this?
                          Mike
                            Ross Macintosh
                            I've seen the toilet tank sink idea before. Alan is right that it is a common penal ware configuration. More interesting is there are conversion kits available for regular residential toilets. The ones I've seen come from Japan and the water flows each time you flush. Rather than just fill the tank directly, the water is routed up to the sink. They are marketed in North America not so much as a space saver but as a way of making better use of the water. Typically the water would just be cold and if you used soap then yes the bubbles would end up in the toilet bowl. That might be a good thing as it might help keep the bowl clean.
                            'Real Goods' used to sell the conversion kits.
                            Regards, Ross
                              tomsdesk
                              Perhaps I should have explained my facetious vernacular: KDOC is Kansas Department of Corrections :`)
                              I too would have trouble knee-hugging then bending over the toilet to brush my teeth.
                              2.5D Trees & Shrubs!
                                bytor
                                If you follow the link Alan posted - you see that the typical correctional version has the direct on orientation of the two "features"at a 45 deg. angle - which is usualy how the chase in a cell is set into the corner. They even make accessible versions of these combi-units for HC cells.
                                Tom - our work is all on the east coast, but the DOC vernacular is way too familiar as it applies to most states we have done work in.
                                Bytor
                                  tomsdesk
                                  Yeah, ours were at 45deg too...the security construction was particularly fascinating to me (as well as the stories by the corrections officials of how often it was defeated by bored inmates with ingenious tools made from seemingly innocuous materials :`)
                                  • boofredlayB Offline
                                    boofredlay
                                    Now just add a urinal and a bidet and you have one stop shopping ๐Ÿคฃ
