    Blogs?
    261 Posts 17 Posters 15.3k Views 17 Watching
      The biggest advantage of using .css (at least in my opinion) is that content and presentation are separate. Content can effortlessly be changed without effecting presentation, and presentation can be changed across the entire site without effecting the actual content.
      That's what I mean, first of all, too.
      Probably because I myself am a total amateaur in this field myself, I never really think it over how to design my sites so I need to change things on the fly. It can be a nightmare checking for hours that every page has been properly changed or not.
      Well, I don't use templates - that's the other thing. I also found some templates really heavy loading and css (especially when in a separate file) needs to load only once and is kept in the cache for the entire session. Then I can concentrate on the content and the download size of it instead of needing to consider the template size, as well.
      I perfectly know that frames are supposed to be a bit "outdated" today (and all is for divs) but again, the advantage of frames is that you can have some constant content loaded from exactly the same file - therefore already being in the cache - and it speeds download time up.
      Ah yes, and I'm also a lazy ass...
        rsw
        I've never used templates either until now, and thats only to use as a the underlying structure of the site, rather than for its presentation.
        frames are outdated but iframes aren't. however i would stil not use them (personal preferance more than anything) and simply separate header, menus, content and footer into separate files and join them up with php or something similar (but obviously not everyong has access to a server with php, or wants to use it even if they do)
        Richard
          Yes, this php include thing is what I'm thinking about now, as well. That has all the advantages of frames, too.
          BTW Why is that "outdated"? Works fine - that's the main thing!
          • EdsonE Offline
            Edson
            @alan wood said:
            I think that’s what you were after.
            alan,
            unless i misunderstood your explanation, that is not what i am after. i do not want a coloured rectangle behind the active nav bar item. i want the actual word to change colour. and this is something i could not find yet. perhaps i will have to deal with an image of it replacing the active item.
            thanks anyway.
            http://www.mahfuz.arq.br
              Well, Bruce, you're right.
              I actually "maintain" and constantly try to add content to my sites and for me (as I'm not a designer), this css thing has helped a lot. All I've learnt from was lurking source codes.
              But sure, I'm aware that this topic is not about us all conversating but about some "courses" through which these guys can learn the basics (and hopefully the "heights") of website building so let's not hijack the thread...
              Good work guys and I'll keep an eye on you!
                rsw
                ...if you are suggesting .css is for improving dynamic page content....
                thats not what i was suggesting, take this forum for example, the content is dynamic, and generated by a lot of php code, if the presentation was tied into the code and not separate from the content, it would probably be very difficult to change the presentation - it relies upon having a separate .css file (and .tpl files). Hope that makes sense.
                (I promise, my last comment on this...content effects presentation and presentation effects content....they need to change together.
                when i talk about content i mean (in general at least) the actual words and images which provide the information and focus of a page, and not the fancy graphics, rollover effects and layout of the page (which in my opinion is the style of the page). Adding a paragraph of text or adding an image does not and should not effect the style, neither should changing the style of a page effect the content. I will accept that the content and style should be considered in unison and that having them separate is an advantage in terms of management. I agree changes to the style and content will directly effect the overall presentation of a page. I guess what i'm saying is that style and content are independent from each other but both effect the presentation of a page. So i guess i'm not disagreeing with you, we just have different ways at looking at the same thing. hope you understand what i'm getting at, but if not it doesn't matter. In the end I think we'll agree to disagree.
                I appreciate the inspiration
                glad to be of help! 😄
                Edit : sorry to hijack the topic!
                Richard
                  alan wood
                  Hi guys,
                  As a newbie to web page design I would like to say that I am facinated with input from the more experienced web builders. I dont think the topic has been hijacked by anyone.
                  Thanks for your input
                  Edson,
                  Re my previous posting as a solution to your quesiton. Sorry, I completly missed the point,and do not have the answer for that.
                  cheers
                  Alan
                    rsw
                    Richard I think we are just moving from context to context which makes it hard to follow
                    Sorry, my trail of thought often wanders around a bit like that, but the only reason i mentioned a forum was to use as an explanation for my comment about .css and dynamic content (as this is a forum it just seemed the most obvious thing to choose).
                    I would like to point out that i understand where you are coming from, and the reasons why you are using the yahoo sitebuilder, and for beginners it probably is the best way of doing things.
                    From what started as a mere observation (and thats all it was intended to be) about html/css/validity/semantics has diverted the topic a little off course (which i didn't mean to do). with this in mind, I will make this my last comment on this subject, unless there is a specific request which i could help with.
                    Richard
                      alan wood
                      Hi Modelhead,
                      I'm in the process of updating my web page with images.
                      I have a book by Ken Milburn on photoshop 7, and there is advise there with regard to what type of image to place on a web page.
                      He talks about the advantages of GIF with regards to animation(havent the foggiest if I will ever use that), and there is obviously jpg.
                      Now I do believe that I should be placing images that are around 72dpi in jpg.
                      Question.
                      Do you see further down the learning curve that maybe GIF would be benifitial to my web page, or should I look at sticking with jpg for now.
                      Alan
                        alan wood
                        Hi Modelhead,
                        That's clear.
                        Thanks.
                        Just to let you know that I will be unavailable most of tomorrow, having some work done on the house, in fact it might spread into Sunday.
                        (Having three windows fitted)
                        Have good good weekend.
                        Cheers
                        Alan.
                        • EdsonE Offline
                          Edson
                          ...in the mean time point me to the place in your page where you want to do this so I can see it in context
                          bruce, i am posting 2 images to tell you what i want. i would like to make very clear where people are in the site. so in pict 2 people would know that they are in the office>>staff section, as well as in pict 1 they would know they are in the portfolio>>architecture section, viewing image #1 of the sevilha92 project because those words would have turned to white and will stay that way while they are at those particular places.
                          only the words would change colour (from gray to white, eg), no backgrounds. i find this a subtler way of signaling what i want. i hope i got the idea across.
                          cheers
                          • EdsonE Offline
                            Edson
                            i will examine it careully as soon as i have the time for it. meanwhile, check this site for an example. the words turn from white to black and vice-versa as you put your mouse over them and, as you move in by clicking on, say habitacional passing the mouse over the project names shows a preview of the projetct to be seen in detail if you click on that name.
                            talk to you later. have a couple of questions unrelated to navigation. thanks.
                              alan wood
                              Hi Modelhead,
                              Re the models:
                              I love the idea of you rending some of the models. It would be great to see them come to life.
                              I decided some time ago that I would stick with sketchup renders. I think woodworkers would be happy to have a very high standard of content, with regard to ‘how to do things’, rather than superb rendering. Maybe one day I will travel that path, but at present I have other priorities.
                              Long term vision I have is maybe an avi from my sketchup model, with voice over explaining what we will be covering in detail in that lesson, just to give an introduction to the topic.
                              I have also thought of a tour of my virtual workshop in avi. format on my home page. But that is some way down the line for me.
                              I am conscious of the fact that you are extremely busy and don’t want to ask you to add more to your workload.
                              cheers
                              Alan
                              • EdsonE Offline
                                Edson
                                bruce,
                                just picked at the new luxwood site. it really looks good and much better than what they have now without being radically different.
                                i like very much the moving bit of text. it ocurred to me to use something like that when i wish to inform some news in my site. can it be done with yahoo sitebuilder?
                                cheers.
                                  alan wood
                                  Hi Modelhead,
                                  What a difference a new designer makes. Congratulations on the new format for their web page. So much more interesting with the image at the top of the page.
                                  The idea that memebers of staff can upgrade the web site makes for a more efficient business, updates in real time.
                                  I am working away in the background reducing the size of the images on my existing web page, and working on an iframe presentation for the home page.
                                  Looks like the windows will be fitted today so I will be able to communicate tomorrow.
                                  cheers
                                  Alan.
                                  • EdsonE Offline
                                    Edson
                                    bruce, my question is not related to the design aspect of my site.
                                    you know i have a current site that is hosted by a brazilian server. even though i want to replace its design and contents i would like to retain the domain as it is known and makes a lot of sense to me. http://www.mahfuz.arq.br: mahfuz is how people know me in the architectural and academic community, arq means that my site is related to architecture and br is brasil.
                                    my question has to with keeping the domain but taking advantage from what i am learning. some thoughts occur to me. while i am working with sitebuilder i could establish a link from that domain to the yahoo one so that what will be accessed is the one i am building right now. thus i could take immediate advantage of what i am learning. could it be done so that people do not perceive the move, that is, that they were redirected to my new site?.
                                    in the near future i want to move my site from sitebuilder to dreamweaver so that it can be hosted anywhere. how can this be done? can a site be exported from sitebuilder? if yes then i might as well start playing with my new site on dreamweaver as a way to learn how to use it.
                                    cheers.
                                    • EdsonE Offline
                                      Edson
                                      bruce,
                                      eventually i will have only one tool and one server. another reason to keep the old address is that my email address is tied to it, and this is even more used than the site's address.
                                      but for now i do want dreamweaver to replace sitebuilder, at least not until i know fairly well how to use it. all i want to do is play with the files generated in sitebuilder in DW. perhaps all i have to do is make a copy of my site's folder and play with that in DW.
                                      i will try to get on with the 2 latest lessons today. yesterday was dedicated to overseeing my kid's school work, going to a soccer match, etc.
                                      cheers.
                                      • EdsonE Offline
                                        Edson
                                        even though this is going to be a difficult week (as i am hosting a spanish architect both at school and at my home) i am back to site building.
                                        i pasted the code you posted for me on my site and all i got was two scroll bars. is this what i was supposed to get?
                                        as for the next posting (17 Aug 2007, 18:54) i do not really get what you mean about "It is a good idea with this editable piece of the script (because it requires fiddling with the html to edit) to arrange it in your html file like you see below so you can easily see the editable areas".
                                        cheers.
                                        • EdsonE Offline
                                          Edson
                                          hi bruce,
                                          just to keep you updated on my progress.
                                          since i have found a layout that i like, i am slowly including all the projects i want to have in my site. some of them have to be converted from previous layouts to the final one. it is all very much time-consuming as it is done by hand (no automation in sitebuilder). every project i include or correct has to be done twice, as i decided to make the site bilingual.
                                          but it is coming along nicely, or so i think.
                                          meanwhile, i am investing some time on learning dreamweaver. i bought some books and am following their tutorials with attention. soon i will be able to work on the site with it.
                                          do you remember i had asked you about how to export a site from sitebuilder to dreamweaver? i am still wondering how to do it.
                                          cheers.
                                          • EdsonE Offline
                                            Edson
                                            i am using CS3 but i also have CS2.
                                            another important question: where in SB do i include the keywords, the so important info that would make it easier for my site to be found on the www?
                                            cheers.
                                            edson
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
