    Exterior panorama
    43 Posts 15 Posters 8.8k Views 15 Watching
    • Didier BurD
      Didier Bur
      For those who like panoramas: have a look at:
      http://www.wpanorama.com/panoramas.php?page=01g&lng=fr
      Resolutions up to 5800x1200, lots of 360Β° to download, vertical panoramas, sorted by themes, check them in the left pop-up menus.
      DB
        remus
        oooh, good site, im going to have to do a few more renders so i can use those as backdrops.
        • urgenU
          urgen
          thanks,Didier.it,s a good resource! πŸ‘
          --pupil forever...------
          • CraigDC
            CraigD
            Just for some closure, we're looking into this problem and will give updates when we know more. Thanks for bringing it to our attention!
            Cheers,
            - CraigD
            Google SketchUp
            • O
              otb designworks
              Thanks for the update, Craig. And thanks for making sure support saw this.
              you are da man, man
              Cheers, Chuck
              OTB Designworks is on Youtube
              • GaieusG
                Now I'm pretty sure that in this topic the problem was/is the same.
                πŸ˜’
                • O
                  otb designworks
                  I have sent an enormous letter to support with a breakdown of all of the major bugs in Sketchup that effect me on a day to day basis.
                  I have not heard a word back from them, but at least they have the list, with descriptions and suggestions.
                  Hopefully, SU7 will address all of these, or at least the major ones.
                  I think that Gaieus is correct concerning the other thread; it certainly sounds like the same issue.
                  Here's to support blowing us away with their progress! (fingers crossed...)
                  Cheers, Chuck
                  • AnssiA
                    Anssi
                    I'm just wondering:
                    Support for some image formats (TGA was brought to my notice by a thread in the Groups) seems to have been silently removed from the PC version. Were the original images TGA:s?
                    Also, at least Photoshop recognizes two ways to write many image formats: the Mac and PC byte orders. Generally the PC byte order works excellently with both the PC and Mac, but files in the Mac byte order format cannot be read by many PC applications (luckily Photoshop can...).
                    Anssi
                    • GaieusG
                      With that Hungarian example it was jpg's. However this might be an answer - the problem is that the Hungarian guy does not really come here too often so I cannot ask.
                      • GaieusG
                        Here is the link to his model:
                        http://sketchup.google.com/3dwarehouse/details?mid=81000b5b9e6f07a3b52f3b0c363015d3&prevstart=0#
                        It shows the same symptoms as Chuck's panorama.
                        • O
                          otb designworks
                          Still no official word, FWIW.
                          Anssi, you make an excellent point. My jpegs were batch processed out of Photoshop on a Mac. I looked through the Photoshop preferences to force a PC compatible version and found nothing that allowed me to change the jpeg version (Mac or PC).
                          Any idea how to change the batch save settings?
                          Thanks.
                          Cheers, Chuck
                          • L
                            l_verio
                            Hi !
                            I made the "hungarian example" Gaieus mentiOned above ...
                            I'm using a mac,
                            and downloaded your panorama from the link at the beginning.
                            WORKS PERFECTLY FOR ME :S
                            • O
                              otb designworks
                              Thanks for the update.
                              I am glad to hear that it worked for you. Apparently, there is some sort of a bug with image exif data. As should come as no surprise, it works on a Mac but PC doesn't work.
                              Cheers, Chuck
                              • T
                                TriciaS
                                Hi Chuck,
                                I think I may know what is going on with this issue. I believe your images have an exif (common to digital cameras) format - true? If so, we have finally isolated a bug with exif formatted images. Those images can display correctly on the Mac but fail to display on the PC. Unfortunately, the only workaround that I have found is to save the images with a different format. We are working on this issue though.
                                Does that help?
                                Best regards,
                                Tricia
                                • 2 / 3
