    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 484.9k Views 153 Watching
      remus
      cheers chris, just had a really quick go with it and it seems to work fine for me. Thanks for all the work youve already put into this.
        Daniel S
        Fantastic script Chris!!!
        Hope that somebody pick it up and help with the UI.
        It works very fast!! To show interactively the deformation of the group in wireframe mode (like in Fredo6´s Shear) would be a good feature... perhaps will go more slow.. but will be a time saver because you don´t have to close the group, make a right click and select Update FFD and then wait to see if is the deformation you wanted and then make all the process again to fix it.
        This is other ruby that looks like a SU7 feature 😍.
        Thank You!!!!!!
        Daniel S
          impressive task 😎
          Works fine except the control points stay on the screen after deformation ❓
          • boofredlayB Offline
            boofredlay
            impressive task 😎
            That is the new group created by the FFD. You can simply delete or hide it when done with it.
            This is great! Thanks for this script.
              boofredlay
              Here is a quickie test. I drew a circle with 24 segments and copy/push/pull. Then I ran the script and moved the points.
              This is one more step towards organics indeed. 👍
                THX: very simple indeed ! ☀
                  krash88
                  It looks great in it's current form, but I get this error in the console... Maybe I'm doing something wrong...
                  Error: #<NoMethodError: undefined method definition' for #<Sketchup::Group:0xbec0960>> C:/Program Files/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:224:in analizeLattice'
                  C:/Program Files/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:60:in updateFFD' C:/Program Files/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13 C:/Program Files/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13:in call'
                  • Mike LuceyM Offline
                    Mike Lucey
                    Thanks Chris, this could really be a useful Ruby for SketchUp.
                    I hope someone picks it up (as you say) and copper fastens it.
                    Even if they don't I imagine you will in your own good time
                    finalise the Script 😉
                    Mike
                      CPhillips
                      Ooops! I fixed it and updated the script in the original post. Kwistenbiebel this is probably the same bug you were seeing.
                        CPhillips
                        I can't get this script to work. Nothing happens.
                        I create a sphere, group it, right-click and do 3x3 FFD, enter the new group with Construction Points, move some to another position, exit the group, right-click the sphere group and choose Update FFD. Nothing happens.
                        Can you open the ruby console and see if it is printing any errors?
                          kwistenbiebel
                          ...exactly the same here. I see no errors in the ruby panel though.
                            CPhillips
                            Wow. I tried it on 2 different machines and it works. Maybe you are using a Mac? Altho I don't see why that would make any difference..
                              kwistenbiebel
                              Does the plugin in any means uses web based 'action script' or 'javascript' as I had trouble before with corrupt Iexplorer settings?
                              (I refer to web panel based plugins like Skindigo that failed in the past on my pc due to 'script blockers' )
                                boofredlay
                                It is working fine on my home machine as well as my work machine. Both pc on xp. One new, the other 8 years old. 😲
                                  CPhillips
                                  No other scripts at all. Just pure ruby.
                                  Hrmm. Very strange. Try doing a 2x2 FFD on a simple box. With the ruby console open in case of errors.
                                    Very cool script. Thank you.
                                    I do seem to being doing something wrong with it though. (Leave it to me to break it. 😒 ) See the attached screen grab.
                                    I drew a sphere centered on the blue axis and above the ground plane. After moving a single point marked at the top and updating, the egg moved off to where it is now. What did I do wrong?
                                    Dave screws it up.
                                      krash88
                                      It works great now! thanks for the fix!
                                        CPhillips
                                        [attachment=0:wa4rvigs]<!-- ia0 -->FFD1.JPG<!-- ia0 -->[/attachment:wa4rvigs]
                                        It looks like you did a "Update FFD" without first closing the control point group.
                                          Yup. That's what I did alright. 😳
                                          Thanks for the help.
                                          Dave
                                            Coen's post makes me ask, is there anyway to make this work on a component instead of or in addition to a group?
                                            • 20
                                            • 21
                                            • 1 / 21
