    Text position problem
    23 Posts 5 Posters 2.8k Views 5 Watching
    • Didier BurD Offline
      Didier Bur
      OK, I understand.
      This is doable, but I have not much time to help you by now 😒
      Remind me...
      DB
        Jorgensen
        Hi Didier
        Thank - you have allready helped. I'll se what I can fix myself.
        By the help from this forum, it might be possible πŸ˜„
        Jorgensen
          Jorgensen
          I have a question about the Sketchup.format_area utility.
          My model is in mm, but I would like the result to be in m2 not as Sketchup.format_area shows mm2 - is this somehow possible ?
            Jorgensen
            Its now going the right way... πŸ˜„
            I have one question.
            I have a group on each level of the building (the levelGroup). Each levelGroup contains a number of groups, that holds info for each room, the area and name. roomGroups.
            I then doubbleclick, and get inside a levelgroup, and update the roomGroups.
            To keep track of the roomGroups I use:
            target = Sketchup.active_model.active_entities;
            $areaObjects.push target.add_text text, coordinates
            I then have an array $areaObjects, that cointain all the text added (roomGroups).
            If I wan't to delete/update all the text, I can read the array again and then erase! them, but this will delete all the text on in all levelGroups.
            Is there a way to tjek if the roomGroup is inside the active group ?
            Jorgensen
              Didier Bur
              Yes:
              Switch to meters unit just before the format_area instruction, then switch back to mm:
              old_unit=Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
              Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=4
              then_call_the_format_area_instruction_here
              (result is a string so it would'nt be affect by later changes)
              Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=old_unit
              (to switch back to mm in your case
              DB
                Jorgensen
                Hi Didier
                Thanks for your reply. Just the way I would do, I just could'nt find the settings in Ruby.
                One problem however, the text now becomes 14 Meters2 - should be 14 M2 - I guess I'll have to do somekind ereg_replace....
                Thanks for your help.
                Jorgensen
                  Jorgensen
                  Easy area = area.sub("eters ", "") πŸ˜„
                  This is fun 😍
                    I did an AreaFormat tool a while ago... see: http://www.sketchucation.com/forums/scf/viewtopic.php?p=12808#p12808
                    It could easily be adjusted to suit your current units if they are not listed...
                      Jorgensen
                      Thanks TIG - I'll have a look at it...
                      Right now I have a problem, actual the last before I can use the script at work...
                      I use this to tjek and delete objects in the active group:
                      def tmAreaDelete
                      objects_active = Sketchup.active_model.active_entities
                      for object in objects_active
                      if($areaObjects.include?object)
                      object.erase! unless object.deleted?
                      $areaObjects.delete object
                      What teases me, is I have to run the tmAreaDelete tree times to delete all text objects - and I just can't se why 😞 It works if I skip the line '$areaObjects.delete object' but that can't be a good solution.
                      Jorgensen
                        Jorgensen
                        And a other problem:
                        The array $areaObjects, is not saved inside the file - so next time it is loaded - one have to manuel delete all the textobjects and add newones -
                        Is there a smart workaround here ?
                        Jorgensen
                          Jorgensen
                          It seems that I can use
                          model = Sketchup.active_model
                          data = model.get_attribute "TM_area", "textObjects", "default"
                          and
                          value = model.set_attribute "TM_area", "textObjects", objects
                          • daikuD Offline
                            daiku
                            J:
                            You are deleting entities from the active entities list while you are iterating over the same list. In other words, you are scrambling the list whilst travesing it. Don't do that. Collect all your enities into a seperate list. Then interate through that list and delete them. CB.
                            Clark Bremer
                            http://www.northernlightstimberframing.com
                            • 2 / 2
