    D/Code - smells like IRB spirit (1.0 RC1)
    22 Posts 5 Posters 3.8k Views 5 Watching
      tomasz
      Ok. Understood.
      My first thought was that it is a sort of debugger 😄 First thing I have done - I have loaded 'real' script too check how it goes 😄
      I am testing it and it is excellent for learning Ruby 👍
      and testing some small procedures.
      1st bug - when I press 'Select all' beside Input browser displays Page Cannot be dispayed.
      Firefox, SU6
      Tomasz
        azuby
        Firefox in Sketchup? 😲 I thought they integrated only Internet Explorer. How have you done this?
        Thanks for the bug report.
        azuby
        *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
        Bad English? PM me, correct me. :smile:**
          tomasz
          It is my default browser.. but you are right - message comes from IE. 😒
            tomasz
            2nd 'bug': when thread.new has been initiated in following manner
            	Thread.new do
            		system(`program arg`)
            then d/Code will wait with displaying its window till the program closed.
            btw. Thread works well with passing arguments to exe. Thanks again.
            Tomasz
              Jorgensen
              First of all - it is fantastic to be able to test scripts direct inside Sketchup 😄
              Would it be possible to have the input(Select all) window in the top and Code (Raw) window
              windows at the bottom - for me it is difficult to se long lines 😞
              Does one have to have two windows ?
              Could Code(RAW) do it ?
              Sorry, if my questions are noob - byt i'm a noob 😉
              Jorgensen
                azuby
                	Thread.new do
                > 	end
                Tomasz
                OK, have to write this again, because I kicked my posting 😞
                I've tried it with threads and
                • Windows Calculator - system "calc"
                • Ruby interpreter - system "ruby -ne 'gets'"
                  and it immediately came back to the Plugin while the called executables were still running. Maybe it depends on the executable? Don't know.
                @Jorgensen
                This also was possible with the built-in Ruby Console, but it was a pain writing all code in one line 😉
                Changing the layout is possible. At the moment there is no HTML template to edit, it's hard-coded. Also a two-window version could be made, yes. Because I'm not that wise in writing modern HTML and JavaScript code, I have to dive deeper into the possibilities.
                This one I do not understand:
                Do "what"?
                azuby
                  Jorgensen
                  Hi azuby
                  The problem is, that I have so sidescroll the window to see long lines.
                  It might be just me (noob), but to me a "code window" and "a output" would be fine - does there have to be three ?
                  Jorgensen
                    azuby
                    A I see, Kinder Surprise 😄 - three wishes at once. Yes, you are right, long lines seem to be a bit complicated. Also three windows would be possible - not at the moment (just want to listen for bugs), but for the future. I add it to the todo list.
                    azuby
                    • tbdT Offline
                      tbd
                      hmm, cannot access the site - gives me 212.162.44.242 reports: Destination protocol unreachable on traceroute. in Firefox it just timeouts 😞
                      http://plugins.ro
                        azuby
                        That's not cool, but it's not the server my website is hosted:
                        tracert errorinitus.de
                        Routenverfolgung zu errorinitus.de [62.67.235.128]  über maximal 30 Abschnitte;
                          1    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                          2     *        *        *     Zeitüberschreitung der Anforderung.
                          3     6 ms     6 ms     6 ms  217.0.82.86
                          4     6 ms     6 ms     6 ms  217.5.72.138
                          5    22 ms    21 ms    20 ms  62.156.138.178
                          6    22 ms    21 ms    21 ms  ae-0-56.mp2.Berlin1.Level3.net [4.68.108.162]
                          7    13 ms    12 ms    12 ms  so-1-0-0.mp1.Hamburg1.Level3.net [4.68.128.37]
                          8    12 ms    13 ms    13 ms  ge-4-1.hsa1.Hamburg1.Level3.net [195.122.140.163]
                          9    13 ms    13 ms    13 ms  212.162.44.242
                         10    13 ms    15 ms    15 ms  s28.evanzo-server.de [62.67.235.128]
                        Hope, this helps. For now, try this one.
                        azuby
                        • tbdT Offline
                          tbd
                          tried from two providers - still not working 😞
                          later edit: finally made it work via proxy
                          http://plugins.ro
                            azuby
                            OK, next try with proxy: http://www.behidden.com/ - you have to enable JavaScript checkbox on this website where to put the url.
                            azuby
                              Jorgensen
                              Hi azuby
                              Any news on the development ? 😄
                                azuby
                                Not at the moment. Unfortunately I'm a bit too busy with German law 😞
                                azuby
                                  Jorgensen
                                  oh - hmmmm sounds a bit boring - that might be the reason for the quite quick reply from you 😉
