    D/Code - smells like IRB spirit (1.0 RC1)
    22 Posts 5 Posters 4.0k Views 5 Watching
      azuby
      It's not a step-by-step like a Debugger! One short example:
      class Foo
        def bar
          puts "baz"
      # First step finished.
      Foo.new.bar
      # Second step finished
      So it's not line by line like in IRB:
      irb(main);001;0> class Foo
      irb(main);002;1>   def bar
      irb(main);003;2>     puts "baz"
      irb(main);004;2>   end
      irb(main);005;1> end
      => nil
      irb(main);006;0> Foo.new.bar
      baz
      => nil
      Maybe I can do the "debuggish" way a bit later.
      edit: So you can't write a piece of a class without closing the class. This will result in a SyntaxError.
      azuby
      *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
      Bad English? PM me, correct me. :smile:**
        tomasz
        Ok. Understood.
        My first thought was that it is a sort of debugger 😄 First thing I have done - I have loaded 'real' script too check how it goes 😄
        I am testing it and it is excellent for learning Ruby 👍
        and testing some small procedures.
        1st bug - when I press 'Select all' beside Input browser displays Page Cannot be dispayed.
        Firefox, SU6
        Tomasz
          azuby
          Firefox in Sketchup? 😲 I thought they integrated only Internet Explorer. How have you done this?
          Thanks for the bug report.
          azuby
            tomasz
            It is my default browser.. but you are right - message comes from IE. 😒
              tomasz
              2nd 'bug': when thread.new has been initiated in following manner
              	Thread.new do
              		system(`program arg`)
              then d/Code will wait with displaying its window till the program closed.
              btw. Thread works well with passing arguments to exe. Thanks again.
              Tomasz
                Jorgensen
                First of all - it is fantastic to be able to test scripts direct inside Sketchup 😄
                Would it be possible to have the input(Select all) window in the top and Code (Raw) window
                windows at the bottom - for me it is difficult to se long lines 😞
                Does one have to have two windows ?
                Could Code(RAW) do it ?
                Sorry, if my questions are noob - byt i'm a noob 😉
                Jorgensen
                  azuby
                  	Thread.new do
                  > 	end
                  Tomasz
                  OK, have to write this again, because I kicked my posting 😞
                  I've tried it with threads and
                  • Windows Calculator - system "calc"
                  • Ruby interpreter - system "ruby -ne 'gets'"
                    and it immediately came back to the Plugin while the called executables were still running. Maybe it depends on the executable? Don't know.
                  @Jorgensen
                  This also was possible with the built-in Ruby Console, but it was a pain writing all code in one line 😉
                  Changing the layout is possible. At the moment there is no HTML template to edit, it's hard-coded. Also a two-window version could be made, yes. Because I'm not that wise in writing modern HTML and JavaScript code, I have to dive deeper into the possibilities.
                  This one I do not understand:
                  Do "what"?
                  azuby
                    Jorgensen
                    Hi azuby
                    The problem is, that I have so sidescroll the window to see long lines.
                    It might be just me (noob), but to me a "code window" and "a output" would be fine - does there have to be three ?
                    Jorgensen
                      azuby
                      A I see, Kinder Surprise 😄 - three wishes at once. Yes, you are right, long lines seem to be a bit complicated. Also three windows would be possible - not at the moment (just want to listen for bugs), but for the future. I add it to the todo list.
                      azuby
                      • tbdT Offline
                        tbd
                        hmm, cannot access the site - gives me 212.162.44.242 reports: Destination protocol unreachable on traceroute. in Firefox it just timeouts 😞
                        http://plugins.ro
                          azuby
                          That's not cool, but it's not the server my website is hosted:
                          tracert errorinitus.de
                          Routenverfolgung zu errorinitus.de [62.67.235.128]  über maximal 30 Abschnitte;
                            1    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                            2     *        *        *     Zeitüberschreitung der Anforderung.
                            3     6 ms     6 ms     6 ms  217.0.82.86
                            4     6 ms     6 ms     6 ms  217.5.72.138
                            5    22 ms    21 ms    20 ms  62.156.138.178
                            6    22 ms    21 ms    21 ms  ae-0-56.mp2.Berlin1.Level3.net [4.68.108.162]
                            7    13 ms    12 ms    12 ms  so-1-0-0.mp1.Hamburg1.Level3.net [4.68.128.37]
                            8    12 ms    13 ms    13 ms  ge-4-1.hsa1.Hamburg1.Level3.net [195.122.140.163]
                            9    13 ms    13 ms    13 ms  212.162.44.242
                           10    13 ms    15 ms    15 ms  s28.evanzo-server.de [62.67.235.128]
                          Hope, this helps. For now, try this one.
                          azuby
                          • tbdT Offline
                            tbd
                            tried from two providers - still not working 😞
                            later edit: finally made it work via proxy
                            http://plugins.ro
                              azuby
                              OK, next try with proxy: http://www.behidden.com/ - you have to enable JavaScript checkbox on this website where to put the url.
                              azuby
                                Jorgensen
                                Hi azuby
                                Any news on the development ? 😄
                                  azuby
                                  Not at the moment. Unfortunately I'm a bit too busy with German law 😞
                                  azuby
                                    Jorgensen
                                    oh - hmmmm sounds a bit boring - that might be the reason for the quite quick reply from you 😉
