    D/Code - smells like IRB spirit (1.0 RC1)
    22 Posts 5 Posters 4.0k Views 5 Watching
      azuby
      Tach (in Berlin we say "Tach"),
      we all know that the Ruby Console is a bit - umm - uncomfortable. And we all know IRB and Wirble (do we?) and maybe CodeRay. I try bringing back the IRB spirit to Sketchup.
      Here is a first screenshot of the UI:
      First screenshot of Sketchup Ruby Plugin d/Code
      Most of the stuff already runs. There is still a bad bug with the Load button. Pressing this button too fast will kill Sketchup. That's not cool, but i really do not know, why this takes place.
      We will see, maybe the output also reaches the level of Wirble.
      azuby
      *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
      Bad English? PM me, correct me. :smile:**
        Didier Bur
        Sounds promising !
        I use RDE but it is a pain to test bits of code with the ruby console window.
        BTW, what is the "Export HTML" button for ? And "Encoded", "Decoded" ?
        DB
          tbd
          you must disable the load button until you finish the eval of the code as SU Ruby is not reentrant
          export html I think is for exporting the code highlighting and encode/decode for script encryption
          I also did something similar for SU5, before WebDialogs, with tab completion and aliases. if you want I can share the source as I dont have time to finish it 😎
          http://plugins.ro
            azuby
            I don't think there is a need to disable the Load button, because there is less Javascript. So I build the page every time the user loads a file, changes the view or sends/executes his code. I know what will happen, if the user enters a infinite loop (or maybe a time consuming one) 😄 but still haven't tried it.
            It's a simple action that causes the error:
            • Run Sketchup
            • Call the d/Code console (click the Button or menu entry)
            • Click the Load button -> BOOM!
              That means, everything is done in the window when I can click the Load button. But maybe Sketchup is a bit slower and hasn't registered the callbacks. Really don't know.
            Export HTML is for exporting the current view without buttons and input field. If you have the "decoded" view and the output field, both will get exported.
            Encode/decode is simple. You know. 😄 For a bit more comfort.
            I'm interested in your code, if it is Ruby 😉 (I guess it's not)
            azuby
              azuby
              OK, here we go again. I've uploaded d/Code 1.0 RC1 to my server.
              Download it from http://www.errorinitus.de/ > Software > d/Code
              Features
              • Load and show file
              • Syntax beautifying for Ruby files
              • Syntax highlighting for Ruby, C, YAML, RHTML, HTML, XHTML, XML files
              • Views for encoded, decoded, beautifyed and raw code
              • Encryption if Sketchup Ruby Scrambler is availble
              • Export current view as HTML file
              • Open current file with system preferences
              • Write current code to source file
              • Write current code to new file
              • Reset code field
              • Clear complete view
              • Select all code in input field
              • Select all code in output field
              • Encode current Ruby code
              • Decode current Ruby code
              • Step-by-step evaluate current (Ruby) code
              • Mulitlanguage support (English and German at the moment)
              • Toolbar icon for fast access
              • Menu position configurable
              • Separate shortcut definition files for each language
              • Resizable window
              • Set window back to defined position and size
              • Toggling on and off via Sketchup "Windows > Preferences" possible
              There also are help files included in the download, but you also can reach them directly:
              d/Code help file (English)
              d/Code-Hilfe-Datei (German)
              There now is one more button to encrypt files if you have access to the Sketchup Ruby Scrambler.
              Hope it runs on Windows and Mac. Should ... but only have tried it on Windows XP pro.
              azuby
                tomasz
                Thank you, Azuby! Step by step..! testing ❗
                Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                  azuby
                  It's not a step-by-step like a Debugger! One short example:
                  class Foo
                    def bar
                      puts "baz"
                  # First step finished.
                  Foo.new.bar
                  # Second step finished
                  So it's not line by line like in IRB:
                  irb(main);001;0> class Foo
                  irb(main);002;1>   def bar
                  irb(main);003;2>     puts "baz"
                  irb(main);004;2>   end
                  irb(main);005;1> end
                  => nil
                  irb(main);006;0> Foo.new.bar
                  baz
                  => nil
                  Maybe I can do the "debuggish" way a bit later.
                  edit: So you can't write a piece of a class without closing the class. This will result in a SyntaxError.
                  azuby
                    tomasz
                    Ok. Understood.
                    My first thought was that it is a sort of debugger 😄 First thing I have done - I have loaded 'real' script too check how it goes 😄
                    I am testing it and it is excellent for learning Ruby 👍
                    and testing some small procedures.
                    1st bug - when I press 'Select all' beside Input browser displays Page Cannot be dispayed.
                    Firefox, SU6
                    Tomasz
                      azuby
                      Firefox in Sketchup? 😲 I thought they integrated only Internet Explorer. How have you done this?
                      Thanks for the bug report.
                      azuby
                        tomasz
                        It is my default browser.. but you are right - message comes from IE. 😒
                          tomasz
                          2nd 'bug': when thread.new has been initiated in following manner
                          	Thread.new do
                          		system(`program arg`)
                          then d/Code will wait with displaying its window till the program closed.
                          btw. Thread works well with passing arguments to exe. Thanks again.
                          Tomasz
                            Jorgensen
                            First of all - it is fantastic to be able to test scripts direct inside Sketchup 😄
                            Would it be possible to have the input(Select all) window in the top and Code (Raw) window
                            windows at the bottom - for me it is difficult to se long lines 😞
                            Does one have to have two windows ?
                            Could Code(RAW) do it ?
                            Sorry, if my questions are noob - byt i'm a noob 😉
                            Jorgensen
                              azuby
                              	Thread.new do
                              > 	end
                              Tomasz
                              OK, have to write this again, because I kicked my posting 😞
                              I've tried it with threads and
                              • Windows Calculator - system "calc"
                              • Ruby interpreter - system "ruby -ne 'gets'"
                                and it immediately came back to the Plugin while the called executables were still running. Maybe it depends on the executable? Don't know.
                              @Jorgensen
                              This also was possible with the built-in Ruby Console, but it was a pain writing all code in one line 😉
                              Changing the layout is possible. At the moment there is no HTML template to edit, it's hard-coded. Also a two-window version could be made, yes. Because I'm not that wise in writing modern HTML and JavaScript code, I have to dive deeper into the possibilities.
                              This one I do not understand:
                              Do "what"?
                              azuby
                                Jorgensen
                                Hi azuby
                                The problem is, that I have so sidescroll the window to see long lines.
                                It might be just me (noob), but to me a "code window" and "a output" would be fine - does there have to be three ?
                                Jorgensen
                                  azuby
                                  A I see, Kinder Surprise 😄 - three wishes at once. Yes, you are right, long lines seem to be a bit complicated. Also three windows would be possible - not at the moment (just want to listen for bugs), but for the future. I add it to the todo list.
                                  azuby
                                    tbd
                                    hmm, cannot access the site - gives me 212.162.44.242 reports: Destination protocol unreachable on traceroute. in Firefox it just timeouts 😞
                                    http://plugins.ro
                                      azuby
                                      That's not cool, but it's not the server my website is hosted:
                                      tracert errorinitus.de
                                      Routenverfolgung zu errorinitus.de [62.67.235.128]  über maximal 30 Abschnitte;
                                        1    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                                        2     *        *        *     Zeitüberschreitung der Anforderung.
                                        3     6 ms     6 ms     6 ms  217.0.82.86
                                        4     6 ms     6 ms     6 ms  217.5.72.138
                                        5    22 ms    21 ms    20 ms  62.156.138.178
                                        6    22 ms    21 ms    21 ms  ae-0-56.mp2.Berlin1.Level3.net [4.68.108.162]
                                        7    13 ms    12 ms    12 ms  so-1-0-0.mp1.Hamburg1.Level3.net [4.68.128.37]
                                        8    12 ms    13 ms    13 ms  ge-4-1.hsa1.Hamburg1.Level3.net [195.122.140.163]
                                        9    13 ms    13 ms    13 ms  212.162.44.242
                                       10    13 ms    15 ms    15 ms  s28.evanzo-server.de [62.67.235.128]
                                      Hope, this helps. For now, try this one.
                                      azuby
                                        tbd
                                        tried from two providers - still not working 😞
                                        later edit: finally made it work via proxy
                                        http://plugins.ro
                                          azuby
                                          OK, next try with proxy: http://www.behidden.com/ - you have to enable JavaScript checkbox on this website where to put the url.
                                          azuby
                                            Jorgensen
                                            Hi azuby
                                            Any news on the development ? 😄
