    BlackWatercolor
    39 Posts 23 Posters 20.7k Views 23 Watching
      Thank you all for the kind words. Paul, your images are great.
      I've been trying to improve it and came up with an idea to make the sky and ground color black with no gradation. I can make the sky black using Jan's Background Color script. I'm hoping that after he gets his household moved, he'll have time to add control for the ground. I think this will improve the contrast some.
      Unfortunately changing the background color doesn't do the same thing as changing the sky and background.
        alpro
        These styles look great, thanks Dave. Now can someone please explain the correct procedure for getting these installed in my styles folder? When I download I get a win-zip file and when unpacked I get 3 xml files, a png., and a ref. folder. I'm using the latest SU6 Pro on a windows machine. TIA
        Mike
        • boofredlayB
          boofredlay
          Mike
          This is confusing Mike. When I click on the link I get a parent directory with 5 styles files listed. The link is in this post above: http://www.sketchucation.com/forums/scf/viewtopic.php?p=4069#p4069
          From there just click on the style and save it to your Styles folder:
          C:\Program Files\Google\Google SketchUp 6\Styles\New Styles
          I have made a new sub-folder called New Styles to keep them separated from the original ones.
            alpro
            Boo, apparently I must be missing something, when I go to save the file, it's zipped, so if I save it to my Styles folder I get nothing, when I extract the files I get xml files instaed of a .style file which I could then just drop in my styles folder. I'm probably doing something stupid so thanks for the help. I'm not the only one thats missing something here.
            Mike
            @loafin andy said:
            I really like the Watercolour styles, they're lookin' great !!
            But I'm having a problem installing them, I've downloaded the zipped files into my styles folder, but when i unpack them I just get the 3 xml files, a 'ref' folder (presumabley for the 'stroke' line and a doc-thumnnail.png). Am I doing something wrong or is it just a simple renaming exerise to achieve the blackwatercolour.style.
            Not sure where to go from here,as I have not come across this before when downloading a .style file, so if anyone could point me the right direction as to what to do, it would be very much appreciated πŸ‘Ώ
              alpro
              Boo, also look at this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=42&t=5293. The files already have the .style extension, so I can save right to my styles folder or somewhere else and then copy/paste into my styles folder. Never had this problem with the xml files before. Thanks again.
              Mike
              • boofredlayB
                boofredlay
                That is very strange. This is what I get when I click on the first style:
                Try saving the zip file to your styles folder then just renaming the extension from .zip to .style.
                Edit:
                Ah haaaaa, light at the end of the tunnel. It seems as if I might be right, just rename it.
                See Gai's post here.
                http://www.sketchucation.com/forums/scf/viewtopic.php?p=30278#p30278
                  So is all this my fault for doing something wrong? Or is this a Mac thing?
                  I know what you're going to say. Just because I'm paranoid it doesn't mean they aren't out to get me. πŸ˜„ πŸ˜†
                  • GaieusG
                    Edson is also on Mac. It must have something to do how Mac handles the extension.
                    • boofredlayB
                      boofredlay
                      But Mike (alpro) is on a PC. See his stats... Windows Vista. Maybe Vista handles the file like a Mac does???
                      • GaieusG
                        Maybe it's not a problem for me because StyleBuilder is installed for me. Maybe for those with problems, file type association in their browsres should be set (as this is not a common and everyday extension).
                        However at least renaming works.
                        • boofredlayB
                          boofredlay
                          I don't have stylebuilder installed and it works for me just fine.
                            alpro
                            Thanks guys, renaming the file did the trick.
                            Mike
                            • majidM
                              majid
                              as i remember . it must be one of my first syles ( i'd made).
                              huge file size!!!
                              just save it on ur pc . (unzip if zipped) .then u must have *****.style file. copy it to one of your style subfolders ( in syle folder of G sketchup).... njoy
                                marlowe
                                hello dave,I am a new user of this forum.
                                I like very much this style.could you send me the style?
                                thank you very much.
                                best regards.
                                jorgeromera1@gmail.com
                                  mianfeideyu
                                  send me one please~thanx
                                  my email:
                                  shuizhongyu1010@163.com
                                    I've finally uploaded the file. See the original post.
                                    • G
                                      gorygreg
                                      Mike
                                      I hope I did this right also?
                                      I placed similar files(skp.) from a SU materials forum into my C drive/Program Files/Google/Google SU6/Materials/Vegetation(this was for trees).
                                      My only worry was that the other files in this folder were (skm.) files.
                                      I asked the question on the board already, just waiting for a generous repy!
                                      Not sure, I'm just a newbie!
                                      • jcdbJ
                                        jcdb
                                        Thank Dave, I love this Style, I used it on a model I made and did a litle extra filters in PS.
                                        [img=http://img66.imageshack.us/img66/2843/8wfc31200tg6.th.jpg]
                                        http://img66.imageshack.us/img66/5931/8wfc3800cp1.jpg
                                        http://www.acustombuilder.com
                                        • jcdbJ
                                          jcdb
                                          another one
                                          http://img110.imageshack.us/img110/9808/8wfc9777cs5.jpg
                                            Those look great. Thanks for sharing them. I'm glad you like the style but it looks like you've modified it a bit. Would you post your version of it? πŸ‘
                                            • 2 / 2
