    Rendering software comparison
    65 Posts 17 Posters 15.8k Views 17 Watching
      Rob D
      Kerkythea
      Kerkythea GI_High+AA 3mins 25secs
      So the first four are done. The results so far tabulated:
      Podium 18:47
      Irender 0:25
      Vue Esprit 2:12
      Kerkythea 3:25
      Remember, this test is to ascertain a benchmark for use of a renderer specifically with Sketchup, and with minimal experience and setup time, using presets where possible. These figures are to produce a "good" image with minimal tweaking, not the best possible image the software can offer. I think it's fair to say the IRender image failed this particular test since it couldn't handle global illumination i.e it's just a raytrace renderer. Vue needed a few cheats to correct the lighting and the scene needed to be re-framed within Vue because camera wasn't imported. It was the quickest and it will shine, I imagine, with exterior renders.
      Podium and Kerkythea gave the most pleasing lighting for a similar amount of setting up. Both retained the Sketchup camera view which can be essential to your workflow. But the speed difference... 😲
        sepo
        This is completely irrelevant. How can you say similar amount of set up time. Podium works within SU and KT need to import scene from the SU. Same thing apply to Vue....
        Also it all depends on presets. I don't know which one you used for the Podium and how does that compare to any other presets of other render engine. I am afraid this does not help as paints distorted picture. You say the best light was from Podium and KT. That KT image looks washed up (consider it a bad render) and Vue in mu mind looks better.
        • soloS
          This is ridiculous, how can you be equally astute with all these engines to even consider making an informed comparison? You obviously do not know how to use podium or irender well enough to even consider such a comparison.
          Below are three of many Podium renders I have done recently that have taken less time to render than your very bland and simple example scene.
          http://img293.imageshack.us/img293/1373/potty7kq2.jpg
          7 minutes
          http://img250.imageshack.us/img250/5333/1223presthavenrd70fo3.jpg
          14 minutes
          http://img175.imageshack.us/img175/5812/colbertresidence7mn2.jpg
          11 minutes
          Now consider the time saved by using a program within SU without the complicated lighting, exports and material setups.
          Your bias is obvious as well as your inability to use a simple app like Podium properly.
          • StinkieS
            Stinkie
            Did anyone mention Podium's ease of use yet? Not to be overlooked, I think. Ease of use = speed and effiency.
              sepo
              Can You post your model. I would like to ask one of our masters to render it.
                Shaun Tennant
                This is a difficult task to compare rendering software. I think it may be a better idea to have 1 model, with 1 view, expectation on creating the same materials look, and have everyone render it out using whatever they have at thier disposal.
                I use VUE (haven't for about 1/2 year though) and I would think it would be appropriate to run this with normal settings, GI settings, GA settings and HDRI settings, with stock materials. Then set it up the way you would normally set it up, using your custom materials (trying to match what the model is supposed to be) and render your choice.
                Times would be also needed for this experiment - how long to set up, how long to render etc.
                I have often found that the strenght of VUE is that your render will look about 60% done as soon as you import it, and if you sub materials in, that jumps to about 80%... squeezing the other 20%.. well, that isn't easy, as well - Vue takes a loooong time... I personally feel that Artlantis looks too plasticy, but I've seen some cool renders done by ... Andrew? that change my mind... (forgive me, I've been away for too long). Kerky has always seemed harsh and heavy to me, but I've also seen some amazing stuff there too... and I'm sure Podium looks great when a master works...
                This just seems like a lot of work to put together, and at the end.. I don't know what we really will have for comparasin..
                Shaun
                Whether they find a life there or not, I think Jupiter should be called an enemy planet.
                • Jack Handey
                  Rob D
                  I entirely expected to get a lot of stick over this by people backing up their favourite software. But come on, insulting me isn't going to do you or anyone any good. Posting a load of images you've done on Podium isn't going to change the fact that, for a similar quality of output, Podium was slower than Vue and KKt. If there's some obvious way to speed up Podium let me know. The scene is bland and simple for a reason.
                  My thanks to Shaun for a more measured response. Yes, this kind of comparison will irk some people. But it will help counless more.
                  Just a note about set-up times for everyone else reading this. IRender was the fastest because it has an internal material setup function. Kerkythea and Podium were about the same. Don't assume Podium sets up quicker just because it's internal to SketchUp - scenes can need a lot of tweaking. Using the SU2KT exporter to KKT is quick and hassle free, and saved time because a metal material came pre-loaded. Podium doesn't have this (yet).
                    sepo
                    I stand by my response...absolutely irrelevant. What does this shows is that you are able or rather not able to render with various render engines.
                    • soloS
                      So you were baiting the response it seems, and you showed no bias?
                      [Podium was slower than Vue and KKt
                      The current Podium and Kt have the same render engine, if anything with the same even handed setups they should be identical.
                      C'mon seriously grow a chin, calling you bias and unable to use Podium well enough to conduct such comparisons is not an insult, it's a fact.
                      • soloS
                        I concur.
                        My final points on this and all render comparisons is that one cannot accurately square off one against another as there are too many factors involved. The best way to do such a comparison is to actually try them all and find the one that works for you, the one that you will be comfortable with and then keep at it until it becomes second nature.
                        I also feel it's in bad taste to do such comparisons as a biased result, or poor result due to inability to use the software correctly can have serious sales or participation consequences for that company as this is a public forum and people make decisions based on others remarks regardless how informed they are.
                        • FrederikF
                          Frederik
                          Exactly...!
                          This is also a good demonstration of how difficult it is to compare render applications...
                          It has a lot to do with materials used, lights and general set-up... πŸ˜‰
                          I feel it's time to end the discussion here...
                          Although it's very interesting, it's very difficult to compare render applications...
                          It's like comparing digital cameras...
                          Individual people have individual needs, and apart from that people have individual preferences...
                          There's so many things that need to be considered... What's the purpose, do you need a SLR camera, a quick snap... Do you need zoom, how many Mega pixels etc... etc...
                          Some prefer Nikon, oters Canon, others Sony, others Olympus, others Panasonic etc... etc... The list could be endless...
                          By the end of the day, I hope that people use something they feel confident with and will cover their indivisual need... πŸ˜‰
                          Cheers
                          Kim Frederik
                          • StinkieS
                            Stinkie
                            @solo said:
                            if anything wait for Podium version 2 as it will not be KT based.
                            I may have seen 'something' by now. Let me put it this way: I got my wallet handy, as Podium's future looks very, very bright. Some may even be quite surprised. πŸ’š
                            Nuff said - I don't want Sepo and TBD coming after me. πŸ˜‰
                              Max_B
                              I'm bumping this thread because I registered to this forum to see it (image are not allowed for visitors).
                              It's too bad it turned out to be a fruitless argument about such and such.
                              IMO, evaluating / comparing possible companion renderers is useful, even if it should not be done this way.
                              I suggest to put a reference SKP file somewhere (or several if one is not significant enough) and then every contributor skilled with a given renderer could give a try to do its best with it, in a reasonable time. Then when posting result, give some indication of the work session time, the main settings/adjustments, render time etc.
                              What do you think?
                              • soloS
                                Sounds like a reasonable idea actually.
                                Make it happen.
                                  Max_B
                                  Make it happen.
                                  I'm quite new on SU, while more experienced with mechanical nurbs modelers.
                                  So, I'm not the best qualified to submit a SU file, and opening a new thread without it is pointless. Hope someone here, if not the original poster, could propose a good test file. …and open a new thread, which should be kept on subject: submitting rendering test images and reports.
                                    Jon
                                    hmm... alright, but we can't just post any old model. Should be a model that incorporates every possible minute detail to see how different rendering engines handle different attributes.
                                    -A variety of different materials glass, metal (aluminum / chrome), wood, plastic, ect.
                                    -A surface to test bumpmapping
                                    -soft shadows / hard light / spots / omnis / sun
                                    -self illumination / lamp shades / translucency
                                    -sub surface scattering
                                    -reflections / specular stamping
                                    -many different textures to add a material to later
                                    -a good model, high poly with a lot of detail, but not too high
                                    You get the drift.
                                    Maybe a kitchen? Or a simpler scene like a chair and a shelf with a lot of nick knacks?
                                    Jon
                                    KT Team member
                                    • GaieusG
                                      If such a comparison is made there should be both an interior and an exterior scene IMO.
                                      • EdsonE
                                        Edson
                                        max's suggestion is quite reasonable but allow me to say, as a novice in rendering, that given a number of capable rendering applications (we all have seem tremendous results being achieved in a variety of apps: KT, Podium, Maxwell, VRay, Vue, Indigo, IRender, and a long etc) perhaps the most important features in that comparison are:
                                        • how easy it is to use each of them? meaning: can you easily understand where are the main switches and how to achieve the basic tasks of rendering without a 6-month learning curve?
                                        • in other words, how intuitive its use is?
                                        • must you be an expert in rendering to be able to use it? some applications' interfaces are plain cryptic...
                                        • what about its integration with the modeller you use, in our case SUp?
                                        other questions could be added to those but they are sufficient for you to get my drift.
                                        http://www.mahfuz.arq.br
                                          dylan
                                          It is always going to be a pretty pointless exercise in some respects, but one that we all would enjoy seeing the rsults of πŸ˜„
                                          It is a nice idea though Max submitting a default scene to be rendered by the variouse apps.
                                          I just see too many variables to be able to ever get a definate result.
                                          http://dmdarchitecture.co.uk/
                                            remus
                                            Although it is a very good idea, and definetly better than one person attempting to use all the render engines, i still tihnk its too subjective.
                                            When you render a scene, you are effectively interpreting it in a way that you think is appropriate. You do this evey time you apply a material, every time you tweak a setting, every time you alter the camera angle, and the list goes on. What looks right to someone, in terms of say a material, could well look wrong to someone else.
                                            Having said that, it could still be an interesting exercise, and might still provide a better basis for comparison than is currently available.
                                            edit: jsut realised i was a bit hasty there, basically i said in lots of words what dylan managed to distill.
                                            • 3 / 4
