    Rendering software comparison
    65 Posts 17 Posters 12.9k Views 17 Watching
      guite
      Glad to see that KT has a dedicated, jealous team. Its the only render app I have touched since 3d Studio (which version was that...?), now 3ds MAX.
      Guite
      • FrederikF Offline
        Frederik
        Not sure I get the point here... πŸ˜•
        We have just been pointing out the fact that the engine behind Podium is Kerkythea... πŸ˜‰
        So what's there to be jealous about..?? πŸ˜†
        Cheers
        Kim Frederik
        • FrederikF Offline
          Frederik
          @solo said:
          ...if anything wait for Podium version 2 as it will not be KT based.
          Very interesting info indeed...
          And you're absolutely sure about this..??
          What will be the successor..??
          Cheers
          Kim Frederik
          • StinkieS Offline
            Stinkie
            That is shrouded in thick layers of mistery. πŸ˜„
            • soloS Offline
              I am absolutely sure, but being more of a 'Bahaman' I let the dogs out and not the cats. πŸ’š
                guite
                Frederik,
                I don't mean to rub you the wrong way (or any which way for that matter πŸ˜„ ). I had struggled to find the right word for what I wanted to say.
                I had used the word "jealous" as an expression of possesiveness, as in a jealous girlfriend or as in the third definition in Merriam Webster dictionary:
                3: vigilant in guarding a possession <new colonies were jealous of their new independence β€” Scott Buchanan>
                Guite
                  I also guessed you were uing the word in some similar sense... like "anxiously protective". But then I1m not a native speaker so sometimes I also have problems with "fine tuning" the expressions I use... πŸ˜’
                  • FrederikF Offline
                    Frederik
                    Alright... No worries... πŸ˜‰
                    Like yourself, English isn't my native language...
                    I was unsure about what you meant and just didn't get the point...
                    But thanks for clarification... πŸ˜‰
                    Cheers
                    Kim Frederik
                      Rob D
                      The first few results for the Great Sketchup Render Test are in! I've posted the images and render times below for you to make your own comparrisons. A fuller review and explanation of methodology will be on my blog (http://provelo.co.uk/?p=20), but I've currently just got podium written up. Basically (i.e there's more to it), I take the same scene, lit just by the Sketchup sun, and see what the results are with minimal tweaking. Hope this comparrison proves useful! Here's the first few...
                      IRender
                      ![IRender high setting, 25 seconds. Needed infill of ambient light as it was unable to calculate the light "bounce".](/uploads/imported_attachments/MgOO_IRender_high_25s.jpg "IRender high setting, 25 seconds. Needed infill of ambient light as it was unable to calculate the light "bounce".")
                      Podium
                      Podium at 90% setting. 18minutes 47secs. Needed import into Gimp to tweak contrast.
                      Vue
                      Vue Esprit on superior setting, 2 minutes 12 seconds. Needed fill light onto background image.
                        Rob D
                        Kerkythea
                        Kerkythea GI_High+AA 3mins 25secs
                        So the first four are done. The results so far tabulated:
                        Podium 18:47
                        Irender 0:25
                        Vue Esprit 2:12
                        Kerkythea 3:25
                        Remember, this test is to ascertain a benchmark for use of a renderer specifically with Sketchup, and with minimal experience and setup time, using presets where possible. These figures are to produce a "good" image with minimal tweaking, not the best possible image the software can offer. I think it's fair to say the IRender image failed this particular test since it couldn't handle global illumination i.e it's just a raytrace renderer. Vue needed a few cheats to correct the lighting and the scene needed to be re-framed within Vue because camera wasn't imported. It was the quickest and it will shine, I imagine, with exterior renders.
                        Podium and Kerkythea gave the most pleasing lighting for a similar amount of setting up. Both retained the Sketchup camera view which can be essential to your workflow. But the speed difference... 😲
                          sepo
                          This is completely irrelevant. How can you say similar amount of set up time. Podium works within SU and KT need to import scene from the SU. Same thing apply to Vue....
                          Also it all depends on presets. I don't know which one you used for the Podium and how does that compare to any other presets of other render engine. I am afraid this does not help as paints distorted picture. You say the best light was from Podium and KT. That KT image looks washed up (consider it a bad render) and Vue in mu mind looks better.
                          • soloS Offline
                            This is ridiculous, how can you be equally astute with all these engines to even consider making an informed comparison? You obviously do not know how to use podium or irender well enough to even consider such a comparison.
                            Below are three of many Podium renders I have done recently that have taken less time to render than your very bland and simple example scene.
                            http://img293.imageshack.us/img293/1373/potty7kq2.jpg
                            7 minutes
                            http://img250.imageshack.us/img250/5333/1223presthavenrd70fo3.jpg
                            14 minutes
                            http://img175.imageshack.us/img175/5812/colbertresidence7mn2.jpg
                            11 minutes
                            Now consider the time saved by using a program within SU without the complicated lighting, exports and material setups.
                            Your bias is obvious as well as your inability to use a simple app like Podium properly.
                            • StinkieS Offline
                              Stinkie
                              Did anyone mention Podium's ease of use yet? Not to be overlooked, I think. Ease of use = speed and effiency.
                                sepo
                                Can You post your model. I would like to ask one of our masters to render it.
                                  Shaun Tennant
                                  This is a difficult task to compare rendering software. I think it may be a better idea to have 1 model, with 1 view, expectation on creating the same materials look, and have everyone render it out using whatever they have at thier disposal.
                                  I use VUE (haven't for about 1/2 year though) and I would think it would be appropriate to run this with normal settings, GI settings, GA settings and HDRI settings, with stock materials. Then set it up the way you would normally set it up, using your custom materials (trying to match what the model is supposed to be) and render your choice.
                                  Times would be also needed for this experiment - how long to set up, how long to render etc.
                                  I have often found that the strenght of VUE is that your render will look about 60% done as soon as you import it, and if you sub materials in, that jumps to about 80%... squeezing the other 20%.. well, that isn't easy, as well - Vue takes a loooong time... I personally feel that Artlantis looks too plasticy, but I've seen some cool renders done by ... Andrew? that change my mind... (forgive me, I've been away for too long). Kerky has always seemed harsh and heavy to me, but I've also seen some amazing stuff there too... and I'm sure Podium looks great when a master works...
                                  This just seems like a lot of work to put together, and at the end.. I don't know what we really will have for comparasin..
                                  Shaun
                                  Whether they find a life there or not, I think Jupiter should be called an enemy planet.
                                  • Jack Handey
                                    Rob D
                                    I entirely expected to get a lot of stick over this by people backing up their favourite software. But come on, insulting me isn't going to do you or anyone any good. Posting a load of images you've done on Podium isn't going to change the fact that, for a similar quality of output, Podium was slower than Vue and KKt. If there's some obvious way to speed up Podium let me know. The scene is bland and simple for a reason.
                                    My thanks to Shaun for a more measured response. Yes, this kind of comparison will irk some people. But it will help counless more.
                                    Just a note about set-up times for everyone else reading this. IRender was the fastest because it has an internal material setup function. Kerkythea and Podium were about the same. Don't assume Podium sets up quicker just because it's internal to SketchUp - scenes can need a lot of tweaking. Using the SU2KT exporter to KKT is quick and hassle free, and saved time because a metal material came pre-loaded. Podium doesn't have this (yet).
                                      sepo
                                      I stand by my response...absolutely irrelevant. What does this shows is that you are able or rather not able to render with various render engines.
                                      • soloS Offline
                                        So you were baiting the response it seems, and you showed no bias?
                                        [Podium was slower than Vue and KKt
                                        The current Podium and Kt have the same render engine, if anything with the same even handed setups they should be identical.
                                        C'mon seriously grow a chin, calling you bias and unable to use Podium well enough to conduct such comparisons is not an insult, it's a fact.
                                        • soloS Offline
                                          I concur.
                                          My final points on this and all render comparisons is that one cannot accurately square off one against another as there are too many factors involved. The best way to do such a comparison is to actually try them all and find the one that works for you, the one that you will be comfortable with and then keep at it until it becomes second nature.
                                          I also feel it's in bad taste to do such comparisons as a biased result, or poor result due to inability to use the software correctly can have serious sales or participation consequences for that company as this is a public forum and people make decisions based on others remarks regardless how informed they are.
                                          • FrederikF Offline
                                            Frederik
                                            Exactly...!
                                            This is also a good demonstration of how difficult it is to compare render applications...
                                            It has a lot to do with materials used, lights and general set-up... πŸ˜‰
                                            I feel it's time to end the discussion here...
                                            Although it's very interesting, it's very difficult to compare render applications...
                                            It's like comparing digital cameras...
                                            Individual people have individual needs, and apart from that people have individual preferences...
                                            There's so many things that need to be considered... What's the purpose, do you need a SLR camera, a quick snap... Do you need zoom, how many Mega pixels etc... etc...
                                            Some prefer Nikon, oters Canon, others Sony, others Olympus, others Panasonic etc... etc... The list could be endless...
                                            By the end of the day, I hope that people use something they feel confident with and will cover their indivisual need... πŸ˜‰
                                            Cheers
                                            Kim Frederik
                                            • 2 / 4
