    Kerkythea lights/SU arc segments
    7 Posts 4 Posters 4.2k Views 4 Watching
      grdnblak
      Hi all,
      I can't seem to figure out how to make your own lights for use within Kerkythea (not the spotlights or point lights that are readily available) i.e. like a neon or strip light. every time i think i have it sussed it appears as a spot or point light in kerky, any ideas how to do this?
      secondly, is there any way of changing the default number of segments that sketchup chooses for the arcs and circles? its pretty tedious having to change such things individually 😞
      cheers in advance
      gordon
      It's not what you know, it's who you know
        remus
        if you draw a circle in th modle and change th enumber of segments, the default number of segments for that modle will stay the same as the new value you entered. you might be able to lock this for your default template by making a circle, changing the number of sides, deleting the circle and then saving the file and making it your template.
          grdnblak
          i was hoping for something more within the settings so that whenever i start a new project, the number of segments is considerably higher than that of the default of 24. the number of segments only remain at the number you set them for for that particular object, if a new arc or similar is drawn, it always starts of at 24.
            remus
            thats interesting, if i change the number of segments in a model, it stays at that number of segments untill you change it again. just to clarify how i do it: draw circle, then type '(number of segments)s' into the VCB, without the quotes.
            as for just entering a default starting value, im pretty sure there isnt anything easy like a box where you can just type it in. and just a word of warning, having lots of segments might seem like a good idea initially, but if your model gets anywhere close to big it slows SU down a lot (aobut 20,000 faces it starts to slow down significantly, independent of your machine.)
              grdnblak
              very strange indeed, seems to be remaining on the last segment input πŸ˜•
              • jenujacobJ Offline
                jenujacob
                quoting from the about SU2KT ...
                SU2KT version 3.0 6th October 2007
                Freeware SketchUp Exporter to Kerkythea
                Author: Tomasz MAREK
                USAGE:
                1. Any component called 'su2kt_pointlight' or 'su2kt_spotlight'
                  will turn into the corresponding light type. To edit it
                  please select one and use context menu.
                2. To export model to Kerkythea
                  • go to Plugins\Kerkythea Exporter and select 'Export model'
                3. To assign Thin Glass shader to material
                  add 'TG_' prefix to material's name.
                4. To make material appear always bright call it 'EmitFake'
                5. To turn material into light call it 'Emit[#]'
                  where # stands for power of light (8=~100W)
                6. KT Material Libaries can be used now directy in SU.
                  Please use KT Material Import tools.
                For further information please visit
                Kerkythea Website & Forum - http://www.kerkythea.net
                Plug-in is based on Su2Pov written by Didier Bur
                and OGRE exporter by Kojack
                so all u gotta do is make a rectanngle assign a material with the name as shown above .
                hope that helped...
                • FrederikF Offline
                  Frederik
                  Hi Gordon!
                  If you haven't done it already, I suggest that you download the Getting Started tutorial, which should help you achieve what you want to... πŸ˜‰
                  I also encourage you to visit the KT Forum, where you can find many useful tips and tricks... πŸ˜‰
                  I.e. take a look at the neon lamps for a industry hall thread or the neon lights thread...
                  In KT2008 Echo, which will be released on Wednesday, January 30th, you have the option to use IES lights... πŸ˜„
                  To get an idea about what IES is, you can Google it or take a look here...
                  Hope this can help you further..!? πŸ˜‰
                  Cheers
                  Kim Frederik
