    How do you upgrade from versions to versions ?
    4 Posts 3 Posters 885 Views 3 Watching
    • C
      corsair
      Hi ☀ ,
      I'm a user of Sketchup Pro, and I'm about to upgrade to V6.4.112 ...
      I was just curious, how do you upgrade yourself from versions to versions ?
      Do you simply uninstall the old version before installing the new one ?
      Do you simply run the new install exe and then all is fine ?
      For any other software, I usually uninstall the old version then install the new one, saving before any setting/parameters files (to avoid having to re-configure the software one more time) ... but with Sketchup, I can't find any setting files anywhere ...
      Where are stored our settings exactly ?
      Thanks !
        sketchy
        You can install this version right over your existing version with no problems. It will keep all your settings in tact.
        I'm not sure about the settings question though.
        • C
          corsair
          Thanks sketchy.
          I've done as you said, and all is fine indeed.
          By "settings" I meant all the things we choose, check, uncheck, in the preferences (not only the keyboard shortcuts and the files paths).
          Thanks !
          • AnssiA
            Anssi
            On my other computer I have SU versions 3, 4, 5 and 6 happily coexisting (haven't fired up v. 3 for a long time, though).
            Anssi
