    License exceeded one user...
    15 Posts 5 Posters 3.3k Views 5 Watching
      Jackson
      Is this a bug in the latest update?
      I'm on a PC and in the last couple of days have repeatedly been getting the "There is another instance of Sketchup running on your network" message whenever I have 2 instances of SU running on ONE machine. We only have 2 pc's in the office, one desktop, one laptop (I'm on the laptop) and they're both on the same desk so I know for certain that there's no other instance being used. I thought it was weird enough this occurring at work while connected to our network, but then it happened last night when I was sat at home, i.e. not connected to any network. I had 2 SU files open to copy and paste some geometry from one to the other and the 2nd one froze and displayed the warning.
      Jackson
      • EdsonE
        Edson
        no, because i have not installed the latest update yet.
        http://www.mahfuz.arq.br
        • CraigDC
          CraigD
          Hi guys, we'll look into it and let you know.
          Hang in there!
          Edit: Why no update?
          - CraigD
          Google SketchUp
          • CraigDC
            CraigD
            Hi Edson, it looks like you're on Tiger (from your Avatar specs) so here's a little more in depth tuning to try:
            This can occur if there are hung daemons. This can happen a couple of ways, but the most common is SU crashing. Close all instances of SU on the network. Go to the Activity Monitor and force quit the sketchupdaemon(s) if it(they) are running.
            This can also occur if you are connected to a wifi and a hard wire at the same time. The daemon gets confused and doesn't know it is talking to itself.
            Google SketchUp
            • EdsonE
              Edson
              craig,
              if i understood you well, i should turn off all instances on the network BUT the one in trouble, right? because if i turn ALL down i do not see any daemons running.
              by the way, i have not updated because there was some talk about problems related to it earlier in this forum. so i decided to wait a little. do you think it is safe to do it now?
              thanks.
              edson
              • EdsonE
                Edson
                craig,
                i did what you suggested but nothing changed: startup still takes ages and the message about the expired license still shows.
                i am running tiger, yes.
                • K
                  krisbern
                  I get this msg too - I quit, then restart and it works. I'm on a macbook that runs the latest version of leopard.
                  • CraigDC
                    CraigD
                    @edson said:
                    craig,
                    Hmmm... Did you check to see if you have wireless and ethernet connections both on?
                    I think it is safe to update your version of SketchUp. I'm running the latest on my Mac with Tiger and am not having any new problems.
                    I'll look into this a bit more...the clue may be that it's taking a long time to launch..
                    Let me know about the network connections and if upgrading changes this behavior.
                    Cheers,
                    - CraigD
                    Google SketchUp
                    • CraigDC
                      CraigD
                      Hi Krisbern - Leopard is a little different in how it handles this. We're looking into the reports we've seen and will post when we get some information. If you have any different problems or learn any new clues, please post them and we'll take a look.
                      Thanks,
                      - CraigD
                      Google SketchUp
                      • EdsonE
                        Edson
                        @craigd said:
                        @edson said:
                        craig,
                        no wireless connections on. my connection to the internet is via ethernet and it has always been, since i started using SUp.
                        i updated to version 6.4.120 but nothing changed: startup is still very slow and the license keeps expiring.
                        • EdsonE
                          Edson
                          craig,
                          annoyingly, the problem remains the same. what should i do? wipe my machine clean and reinstall SUp?
                          thanks.
                            Justin T
                            I have been having this same problem since at least 10-5-07, when I first filed a bug report. I have reported this bug twice, and the Sketchup team was not helpful either time. The first time, they told me to update to the latest version, even though I was already on the latest version. The second time, they told me it this problem occurs after Sketchup crashed. Which has not been my experience.
                            I am on Leopard and a Macbook Pro.
                            edit: I am using only Wifi, and am using the latest version of Sketchup.
