    Problem with alpha channels (solved)
    4 Posts 3 Posters 922 Views 3 Watching
      mateo soletic
      I am stuck with a problem and cant continue
      working...
      Not quite sure if this is a Maxwell or a
      Photoshop question?
      I just downloaded the newest version 1.6.1
      And when I open the alpha image in
      photoshop I dont get the usual four
      channels RGB,Red,Green,Blue like
      I did before but only one - Gray.
      I did post this on the maxwell forum but
      I really need a quick answer.
      I know this is not a direct SU question so
      dont get mad on me 😠 .
      I have great confidence in this forums
      general knowledge.
      Thank You for any help You can give me.
      Cheers,
      Mateo
      [Concept Illustrations](http://concept-illustrations.com/)
      • Paul RussamP Offline
        Paul Russam
        My first quick thought it to check the image mode (Image Menu/Mode) it should be RGB Colour.
        If its not then change it and check the channels.
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          mateo soletic
          Great , Thanks a lot Paul, that was it. πŸ˜„
            dylan
            general knowledge.
            Good to see Paul proved you right in less than 15 minutes πŸ˜„
            http://dmdarchitecture.co.uk/
