    Some more questions
    33 Posts 8 Posters 6.7k Views 8 Watching
    • chippwaltersC
      chippwalters
      OK, I looked at it. Thanks for doing this, but while I understand how to find the target, and the height offset, I'm not sure I follow the rest of your construction. You have constructed several polygons. Which came first? TIA.
      Currently working with Cross-Reality technologies
      • Wo3DanW
        Wo3Dan
        @chippwalters said:
        Wo3Dan,
        Here one:
        (see previous posthttp://sketchup.google.com/3dwarehouse/details?mid=3bde59bd2cb2eb715953c2937bcaaf81)
        Chippwalter,
        Here is your skp with one scene (nr.6) reproduced:
        (click on C1, C2, C3 and so on till 'closup of target')
        Error 404 (Not Found)!!1
        (sketchup.google.com)
        Several tools you can use:
        -From scene6 zoom in real close using the eyeglass (=Zoom tool), not your mouse.
        This will let you pinpoint (mark) your target.
        -The Walk tool will reveal the actual height from scene6 in the VCB
        The camera is located on the line that I drew towards the little vertical line in the canon (CANNON?!?#)
        The rest is pure constructial and a bit of trial and error to find the camera
        Try to figure it out and let me know.
        • GaieusG
          OK then, maybe this is what you mean by "extruding a path" (see attached skp file).
          You can also copy it along the z axis and hand stitch the polylines together but that's slower.
          ExtudePath.skp
          • B
            bonj
            really great stuff in here..... 😄
            • GaieusG
              Hi bonj (and welcome)
              I hope you can find some useful stuff here... 😉
              • chippwaltersC
                chippwalters
                Yep, that does work for extruding a path-- though a bit convoluted. Perhaps SU can accomplish this simple task in the next vers?
                I did talk to TBD and he says there's an easy way to identify the position of the camera using Ruby. So, I'm off to figure that out 😄
                Thanks everyone for your generous and helpful support!
                • GaieusG
                  You can also just elevate a copy of the curve and then select both and use the curvstitcher.rb or the skin.rb to create the surface. The above method was only about one minute to accomplish however.
                  • Wo3DanW
                    Wo3Dan
                    chipwalters,
                    By now you must be thinking: “this guy is cheating, he just copied that scene”.
                    I only do admit that in my previous explanation not every step is obvious.
                    Also, there I found the camera location by zooming out from the scene to be reproduced.
                    And then when seeing the use of the ‘Walk’ tool, revealing the camera height I new that I could do better.
                    Here is a slightly different approach that is quite accurate (maybe several mm off / over 50m).
                    The difference is that here I use a second target just in front of the camera.
                    See this model (tutorial) in 3DW:
                    But now I would like to know what the benefit might be for you to reproduce a scene?
                    What is your goal?
                    To me it was just the challenge and you ‘forced’ me to refresh my knowledge about the Zoom, Position Camera and Walk tools, so thanks!
                    hope this helps,
                    Wo3Dan
                    p.s. You can also play the animation.
                    and toggle between first scene "(STANDARD SETTING (N))" and scene "reproduced camera location" to see if they are different. Hard to tell!
                    • chippwaltersC
                      chippwalters
                      Yes, that's much clearer, and simple as well. Thanks a bunch for doing that. The reason I want the camera pos, is because I want to light a scene for a Podium render, and I'm used to lighting scenes with a 4 view and camera being shown.
                      TBD tells me there's a way to do this via a Ruby script-- I may check that out too.
                      Thanks a bunch for spending the time to enlighten me. It is VERY appreciated! 😄
                      • Wo3DanW
                        Wo3Dan
                        chippwalters,
                        Yes, I forget to mention that possibility.
                        I don’t even know if there is any such ruby but it should not be that hard to reproduce a scene since that data is saved with the model. The only thing is you have to know where to ‘look’ to fetch it.
                        I enjoyed doing this.
                        success,
                        Wo3Dan
