    Design a SketchUp Conceptual Course
    34 Posts 12 Posters 4.5k Views 12 Watching
      Ray Brown
      Guys:
      Makes sense to me--assuming the class is composed completely of architects or urban designers. I'm not sure Susan's classes are so composed.
      I'm still wrestling with the phrase "conceptual architecture." It seems to me to have multiple meanings, one of which occurred to me this morning: Architecture that can't be built but only thought about. Stuff that violates the laws of physics, or that is basically unusable, or that requires construction technologies that don't yet exist, but looks really good in renderings!
      However, even if that is the definition in question, the solution to using SU to model it remains the same.
      Ray Brown
      Ray Brown Urban Design
      • DanielD Offline
        Daniel
        Susan,
        I've juried enough students to know there are quite a few students (and by extension there are probably professionals who fit this bill) who, when required to produce their projects on the computer they are limited to what they know. In other words, if the only way they were taught to create stairs was in a straight run, then that's all they do. They haven't figured out how to apply those same skills for a different drawing/modelling task. It's quite possible some of your students are doing the same - they aren't trying to figure out how to apply the skills you taught them for a new task, but want you to tell them how to do it. They might have a particular "conceptual design" in mind but haven't made that leap of figuring out how to model it themselves.
        Daniel
        My avatar is an anachronism.
          sorgesu
          Daniel, I quite agree with you. I do believe that is what they want and that is where the failure to connect is. Some people are able to make these intuitive leaps and others need to be spoon fed. Being spoon fed is of no earthly use because it solves only an immediate problem and does not assure that they will be able build on what they have learned when they hit the next challenge. For someone who learns this way, the only way that they can be truly effective is either to learn a limited number of techniques that they can use over and over again because they are not required to do anymore, OR if they are required to do more, then they must be exposed to every conceivable problem solution and digest it. This would require many many hours of exposure. 3-1/2 hours cannot do that for such a learner.
          Conceptual thinking lends itself to a "design" problem, as in Phil's example. Conceptual thinking does not apply itself to a "how to use a tool" problem.
          The conceptual part is in answering the sorts of questions that Phil cited in determining what sort of structure to build and what sort of terrain is likely to result. Once that is determined what remains is how to use the tools in SketchUp to build what it is that has been determined to be required for said concept. I am not attempting to teach a University Architectural Design course. That is out of the scope of the little 3-1/2 hour classes I teach. I am teaching a course on how to use a specifc sorgware applicaton to represent the design. There are 4 courses of 3-1/2 hours each. By the Advanced courses we are indeed doing excercises where we are building complete objects. For instance,we do one where we make a sink. This excercise allows the introduction of several tools in the process. I sometimes get Landscape Architects who express that they would have wished for a Landscape Example. Accordingly at one part of the class we "lathe" ( using follow-me) a shape. I say out loud in the class that , for the Architects we are making a Cap for a Bannister and, for the Landscape Architects, this is Fence Post Cap. The point I am trying to make people understand is that all designers use the same shapes and the same tools and whether you are making a sink or a water cistern or bicycle helmet the principles are the same.
          From a pure business standpoint it is impossible to advertise and sell a class that is basically going to be a call to "show up" and we will shoot the breeze and explore your particular problems together. That isn't going to work. There is a written manual and a curriculum. People want and need to see what will be specifically oovered in a class before they can determine if they want to shell out the money to take it. This is not a college course where we have weeks to explore everyone's issues.
          These courses are intended for busy professionals who want a directed and concentrated course to quickly learn how to use SketchUp from simple tools to more complex problems. They are expected to know how to extrapolate further from what they have learned, as I would expect any employee of mine to exptrapolate.
          Susan Sorger
          Former Seller Hand Rendered Entourage
          Former Canadian Authorized Training Centre, SketchUp
            Phil Rader AIA
            Daniel...spot on.
            I remember once at a job I had one of the interns came to me and asked how to divide a line into 13 equal parts in AutoCAD....I ask that person well how would you do it in the real world...no response...
            Yes I know there is the divide command and it will do the work for you but there is no excuse not to know how to do it in the real world.
            Knowledge is power and what you want to happen is to exert your power (knowledge) into the computer. If you are continually searching for the button to press that does something for you than you are at the mercy of the computer.
            I remember the good old days of SU when it was a very basic but powerful 3d modeling software. It still is but I'm afraid the added bells and whistles may blur the simplistic approach to modeling.
            Oh and my discussion above would work for any group..."OK class today lets design a desk, a shopping cart, a coat, a thingamajig...anything. The important part is the trip down discovery lane questions and answers getting more knowledge about what the "thing" is and what it should look like, how it should function etc. Once the conceptual discovery process is complete than the conceptual modeling can begin. its not a straight path during the modeling phase you will continually refine your concept as the visual aid of the model helps to confirm or reject the validity of the concept.
            So Susan if you can just get your students to remember to use their brain when they model and not to become too reliant on the software.
            http://www.philrader.com
              Ray Brown
              Daniel...spot on.
              Phil:
              Three thoughts:
              Would you agree that because so many users have become so proficient at modeling, we've lost the "sketch" part of what the software was really intended to do?
              Would you also agree that unless an individual considers the process of learning itself to be its own form of fun (and thus its own reward), he or she will not find much joy in exploring and discovering what a wonderful toy like SU will allow you to do?
              Finally, would you agree that the design process is its own form of play?
              Ray Brown
                sorgesu
                Bruce, the waterslide tutorial was not posted here but the problem was posted and many people gave input on how to best approach the problem. The tutorial was not for my class but for an individual who took the class and couldn't figure out how to do it. I started the tutorial for her but ran into a glitch becuse I was expecting the ACAD files to be correct and spot on and they were not. I'm glad I posted because it was a lot of fun seeing all the various approaches.
                As to the good ideas, that were suggested here, such as including examples of many different types of structures designed is SketchUp: check, I already have that, as I said.
                The suggestion to construct something and thereby learn many tools in the process rather than just teach the function of a tool: checkl, I already have that.
                For the most part, what I read here was a general agreement that conceptual architectural application is not something that has a place in a "how to class".
                Finally, to Phil, I would have lots of fun teaching a class where we can "make a chair" one day and "make a lamp" the next day but I would be concerned that any one specific project may not require the coverage of certain tools that I promised to cover in the class. It took me literally weeks to come up with very directed excercises that covered a maximum of useful tools and techniques and then putting that into a manual with each step explained fully was a huge undertaking.
                Leaving that to chance and running into unforseen glitches in class, while a great learning experience, is usually time consuming and again robs the opportunity to cover the required materials. I assure you people taking a class such this are not very patient when something doesn't work quite as expected and you need to re-think it as you go. They get the impression you aren't prepared and aren't knowledgeable. Actually that goes hand in had with expecting an immediate answwer or "button" for how to do this or how to do that. Perhaps what I need to stress over and over in the class, which I don't believe I have ever done, is to verbalize that the answer to how to approach a modelling problem isn't always obvious or instantanesous. That one needs to stop and consider the capabilities of all the tools, make decisions about which may be the best way to go, and be prepared for some false starts and to consider other more efficient alternatives.
                Okay, that thought process really helped. Thanks guys.
                Susan Sorger
                  Ray Brown
                  quote]
                  You know, most of us have done a lot of trial and error, and no small amount of swearing, as we discovered the best, fastest, easiest to manage ways to do things. It's part of the process, and part of the fun of feeling as if there is some small measure of increasing mastery involved.
                  Maybe the majority of your students just can't see that, but I think you're right: explaining to them up front that it's the next step of the process--really, in anything: cooking, golf, design--might take some of the stress off you. You can give them the fundamentals, and the rest is up to them.
                  Ray Brown
                    Phil Rader AIA
                    How many of us have removed a bolt with a pair of vise grips...
                    my father told me if it does not work get a bigger hammer...
                    Ray is right there are a multitude of ways to do any one specific task.
                    Dan I'm only here for a minute so I'll answer you post after the kids are asleep when I have more time.
                    Susan you are right students interest level will wain if you run into glitches during the lesson. But heck the resolving the glitches is part of the learning process and part of the fun...for me at least.
                      Charlie__V
                      Hmmmm,
                      How I see......."it" (Conceptual Architeture) or any other art form.
                      Fresh Fallen Snow.....Mittens/Gloves.......Create your........
                      Slab of Marble......Hammer & Chisel..........Create Your........
                      Blank Canvass.......Oil/Water..........Create Your.......
                      Google SU..........Susan Intro.......Create Your.........
                      Susan, Teach them how to not hit the "wrong" nail.....and let em go!
                      Charlie
                        Phil Rader AIA
                        From Ray
                        Would you agree that because so many users have become so proficient at modeling, we've lost the "sketch" part of what the software was really intended to do?<<<
                        No it's still there it's just getting hidden by all the other features.
                        Would you also agree that unless an individual considers the process of learning itself to be its own form of fun (and thus its own reward), he or she will not find much joy in exploring and discovering what a wonderful toy like SU will allow you to do?<<<
                        Yes. The trip is as important as the destination. Too often in todays day and age people want instant gratification. The world is full or remorse because we satisfy all of or needs and desires is such a short time. I think we should have people do a drawing with a ruling pen
                        http://upload.wikimedia.org/wikipedia/commons/thumb/e/ef/Holding-a-ruling-pen.jpg/518px-Holding-a-ruling-pen.jpg
                        then they will understand the importance of patience.
                        Finally, would you agree that the design process is its own form of play?<<
                        The quality of the design process will show through in the quality of the design. They are one and the same.
                        On a side note I remember reading a book in college about creativity by David Bohm. It's been a long time now but essential one of the points I remember was that human beings have an inherited need to be secure. To express your own creativity is in one way a risk. you are exposing an inner part of yourself for public viewing. in order to maintain our security people will hold on to their thoughts and inner creative side out of fear that their ideas will be rejected. so its safer to just go along with someone else's idea.
                        Essentially the risk takers are the ones that become the new paradigm that those that keep their own creative ideas inside will follow...until a new person steps out of their safe zone and expresses a new idea that becomes adopted as the new way.
                        anyway your use of the word "PLAY" reminded me of this book because if I remember correctly Bohm states that ONLY if we allow ourselves to PLAY will we allow our creative side to take risks and create something that is better and more pleasing than if we restrict ourselves to socially acceptable "business" behavior.
                        think about how happy children are to run through a room with a plastic airplane imagining all the twists and turns and zooming over things and landing an performing maneuvers that a real plane is incapable of doing. In this state of PLAY anything is possible.
                        At some point though we (society) discourages PLAY and tries to beat it out of you...
                        "bobby STOP playing with your food...Bobby Stop playing with your shirt...Bobby Stop playing arround...Bobby you will need to learn to sit still if you ever want to get a job.
                        Etc. Etc. We all smile in total amazement when a 2 year old is playing but by the time they are teenager we discourag play and want them to become worker drones.
                        GET SERIOUS...This is Serious ...yadda yadda yadda
                        I wish as a society we could hold on to the importance and wonderful new ideas that can come from playing arround.
                        OK Now I better get serious and get back to work...hehe.
                        • Mike LuceyM Offline
                          Mike Lucey
                          Hi Susan,
                          Have a look at this link, http://www.thecadacademy.com/arch_solutions.asp I think it covers the information you are after.
                          Mike
                          PS: Thanks for the Card ๐Ÿ˜‰
                          • 2 / 2
