    Need help big time!
    scheduled pinned locked moved Corner Bar
    6 Posts 5 Posters 1.4k Views 5 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
      James,
      Not sure it helps but try this CCleaner out (use the "fix problems" tab) there might be some registry or other "crap" left on your machine:
      http://www.ccleaner.com/
      one-reply-to-this-post last-reply-time reply quote 0
      • N Offline
        not registered yet
        James,
        You might want to give the Windows Tweak UI Powertoy a try. It's got a module called Rebuild Icons that might work for you. If you're not familiar with the Windows Powertoys, they are a series of system utilities created by the Microsoft Windows development team and offered as no-cost downloads from the MS website. Tweak UI offers a number of useful enhancements, mostly Registry hacks, through an Explorer-like interface.
        The XP Powertoys are available at: http://www.microsoft.com/windowsxp/down ... rtoys.mspx
        -Gully
        poster-Gully Foyle
        • N Offline
          not registered yet
          Upon reflection, it occurs to me you might also want to try msconfig. This is a Windows system utility that you can invoke with Run > msconfig. It consists of a tabbed dialog that gives you access to a number of startup options. The last tab lists all the programs and services that run when you start Windows, and gives you the opportunity to disable them. You may see a suspicious-looking program (or several) that you recognize as part of the icon toy that messed you up and just uncheck it or them, deactivating it.
          -Gully
          poster-Gully Foyle
            Shaun Tennant
            James,
            you could also check on the giveaway of the day site, under the day that prog came up to see what the discussion is. I always read through them first, just incase. If someone else had your issue, then they might have also found how to deal with it without you having to further research it. I have seen this type of response before.
            (If anyone knows who got to Coen and my Avatar, please call crimestoppers at 1-800-555-5555 12.50$ reward for information leading to the capture of the perps)
            poster-Shaun Tennant
            Whether they find a life there or not, I think Jupiter should be called an enemy planet.
            • Jack Handey
            • RonSR Offline
              RonS
              Shaun,
              I find it rather becoming of you guys.hehehehehe
              Design is not just what it looks like and feels like. Design is how it works.
              Steve Jobs
              RonS
                Coen, did you hire your look & feel from one of those I see here regularly?! 😄
                • first-post
                  last-post
