    Follow Me tool not working with curve
    21 Posts 11 Posters 11.7k Views 11 Watching
      @Rob, making a group before scaling up only to explode it once you have is a waste of time. You can select the geometry and scale it up if you want. Scale down afterward. Here's another method that I think is easier. Start by making the profile and path for the Follow Me operation at the regular size. Make a component of the lot. Copy the component (Move/Copy) and scale the copy up by a factor of 10 or 100 or something. Open the large copy for editing, run Follow Me and do whatever else you need to do. Then close the large component to exit edit mode and delete it. Return to the original component and the work is done.
      • 2 / 2
