    New 17" MacBook Pro is sweet
    15 Posts 5 Posters 2.3k Views 5 Watching
    • EdsonE
      Edson
      hi mike,
      a couple weeks ago i received a similar machine. mine is the 15" macbook pro to which i added enough RAM to complete its max of 4Gb. my GC is also the NVIDIA 256 Mb. i did not go for the 17" as i plan to take it to school and on the road quite often. I also bought a 20" apple cinema display so that i can work with two screens when at my office.
      do i have to tell you i just love it? even though i had bought a 20" imac four months ago, this is by far the best machine i ever had.
      enjoy your lappy!
      http://www.mahfuz.arq.br
      • Mike LuceyM
        Mike Lucey
        James,
        I downloaded and ran the file,
        Crowd Test
        From Scene 1 to Scene 11 and back to Scene 1
        1920x1200 No Shadows 40 sec
        Is there some other test we could try with this
        file?
        Mike
        • EdsonE
          Edson
          i would like to try alan's file too. perhaps we should ask him for it.
          • T
            todd burch
            Mike, thanks for the info. I use my MacPro (2gb ram, 3ghz dual duos) with the 23" cimema display and I love it. There probably a memory upgrade lurking in my near future.
            I bought a white MacBook (2.16ghz speed, 2gb ram), just this past June to take with me out of the house - with Bootcamp. SU works "ok" under both OS's. On the Mac side, I have to turn Fast Feedback off regardless. To see the selection box for a left-to-right or right-to-left drag select, I also have to turn off hardware acceleration. It's annoying. And, the screen is small, but it works. Havent used SU under the Windows boot enough to remember the settings - probably the same.
            I'll most likely end up getting a 17" MacBook Pro. I'll deck that thing out with VM FusionWare so I can install Windows XP and one of the Linux distrubtions and run all three at once. Probably 4GB as well. Gotta save my quarters first. Thanks for the report!
            Todd
            • Alan FraserA
              Alan Fraser
              It's here folks...in the other place...attachment to the opening post of the thread.
              Error 404 (Not Found)!!1
              (groups.google.com)
              3D Figures
              • EdsonE
                Edson
                i've tested my macbook pro core 2 duo (4MB RAM, GeForce 8600M GT) using james's file. i am afraid it did not fare as well as his lappy.
                1. Animation time scene 1-10 approx 1 minute.
                  (No shadows)
                2. Orbiting with no shadows 1-10 no major problem, except for some lag to start orbiting. the ornament on the column disappears while orbiting but reapperas almost immediately.
                3.(Shadows on) no shadows appear while orbiting, not even on scene 1. it takes some time for them to appear after the orbiting stops.
                1. Shadows disappear and reappear after an increasing amout of time when orbiting, from 2s on scene 1 to 14s on scene 10.
                However, there was no jerkyness in any of the tests.
                i wonder if any of you mac users would know of a way o speeding up those results. increasing RAM and replacing the graphics card is out of the question, of course.
                edit: the RAM mentioned above is 4GB, not 4MB.
                • T
                  todd burch
                  You mean 4GB, right?
                  Todd
                  • EdsonE
                    Edson
                    yes, todd. it would not move with 4MB.
                    • P
                      pmiller
                      James, on your last model -- scene forty orbits in real time, about 2 seconds for textures to reappear. Never got a wireframe.
                      Dual Core 3.4 Ghz
                      nVidia quadro fx 1500, 256 Mb
                      2 Gb ram
                      Windows XP
                      Will try tommorow on a 3.8 Ghz single processor laptop.
                      • Mike LuceyM
                        Mike Lucey
                        Does anyome know if SketchUp will be taking full advantage
                        of Dual CPUs?
                        • Mike LuceyM
                          Mike Lucey
                          I like to leave the MacBook Pro on permanently. I understand
                          that its the best way to run Macs as downloads and maintenance
                          can be carried out over night, I think!
                          Its also a fact that laptops tend to heat up a bit when under
                          pressure, more so than desktops. I thought one way to keep
                          things cool would be to have some control over the fan.
                          I located a utility called Fan Control, it does what it
                          says. Okay if not on mains the battery life is effected but most
                          of my time spent on the laptop when plugged in, so no problem.
                          Also it can be adjusted in on the move.
                          The links for Fan Control, a free application is,
                          http://www.lobotomo.com/products/FanControl/
                          I imagine there is also a free utility for PCs 😉
                          Mike
                          PS: Something for the PC laptops,
                          http://www.diefer.de/i8kfan/index.html
