    New 17" MacBook Pro is sweet
    15 Posts 5 Posters 2.1k Views 5 Watching
    • Mike LuceyM Offline
      Mike Lucey
      James,
      If I remember correctly Alan had a SketchUp file that
      tested the power of any computer. I think it was 1000
      columns or something like that. Does anyone have this
      file handy? It would be a good one to use as a standard
      test model?
      Mike
      • EdsonE Offline
        Edson
        hi mike,
        a couple weeks ago i received a similar machine. mine is the 15" macbook pro to which i added enough RAM to complete its max of 4Gb. my GC is also the NVIDIA 256 Mb. i did not go for the 17" as i plan to take it to school and on the road quite often. I also bought a 20" apple cinema display so that i can work with two screens when at my office.
        do i have to tell you i just love it? even though i had bought a 20" imac four months ago, this is by far the best machine i ever had.
        enjoy your lappy!
        http://www.mahfuz.arq.br
          Mike Lucey
          James,
          I downloaded and ran the file,
          Crowd Test
          From Scene 1 to Scene 11 and back to Scene 1
          1920x1200 No Shadows 40 sec
          Is there some other test we could try with this
          file?
          Mike
          • EdsonE Offline
            Edson
            i would like to try alan's file too. perhaps we should ask him for it.
              todd burch
              Mike, thanks for the info. I use my MacPro (2gb ram, 3ghz dual duos) with the 23" cimema display and I love it. There probably a memory upgrade lurking in my near future.
              I bought a white MacBook (2.16ghz speed, 2gb ram), just this past June to take with me out of the house - with Bootcamp. SU works "ok" under both OS's. On the Mac side, I have to turn Fast Feedback off regardless. To see the selection box for a left-to-right or right-to-left drag select, I also have to turn off hardware acceleration. It's annoying. And, the screen is small, but it works. Havent used SU under the Windows boot enough to remember the settings - probably the same.
              I'll most likely end up getting a 17" MacBook Pro. I'll deck that thing out with VM FusionWare so I can install Windows XP and one of the Linux distrubtions and run all three at once. Probably 4GB as well. Gotta save my quarters first. Thanks for the report!
              Todd
              • Alan FraserA Offline
                Alan Fraser
                It's here folks...in the other place...attachment to the opening post of the thread.
                http://groups.google.com/group/Sketchup-Pro/browse_thread/thread/2ddc0e1594ef13/10cf6db673ae3033?lnk=gst&q=geometry+is+everything&rnum=1#10cf6db673ae3033
                3D Figures
                • EdsonE Offline
                  Edson
                  i've tested my macbook pro core 2 duo (4MB RAM, GeForce 8600M GT) using james's file. i am afraid it did not fare as well as his lappy.
                  1. Animation time scene 1-10 approx 1 minute.
                    (No shadows)
                  2. Orbiting with no shadows 1-10 no major problem, except for some lag to start orbiting. the ornament on the column disappears while orbiting but reapperas almost immediately.
                  3.(Shadows on) no shadows appear while orbiting, not even on scene 1. it takes some time for them to appear after the orbiting stops.
                  1. Shadows disappear and reappear after an increasing amout of time when orbiting, from 2s on scene 1 to 14s on scene 10.
                  However, there was no jerkyness in any of the tests.
                  i wonder if any of you mac users would know of a way o speeding up those results. increasing RAM and replacing the graphics card is out of the question, of course.
                  edit: the RAM mentioned above is 4GB, not 4MB.
                    todd burch
                    You mean 4GB, right?
                    Todd
                    • EdsonE Offline
                      Edson
                      yes, todd. it would not move with 4MB.
                        pmiller
                        James, on your last model -- scene forty orbits in real time, about 2 seconds for textures to reappear. Never got a wireframe.
                        Dual Core 3.4 Ghz
                        nVidia quadro fx 1500, 256 Mb
                        2 Gb ram
                        Windows XP
                        Will try tommorow on a 3.8 Ghz single processor laptop.
                          Mike Lucey
                          Does anyome know if SketchUp will be taking full advantage
                          of Dual CPUs?
                            Mike Lucey
                            I like to leave the MacBook Pro on permanently. I understand
                            that its the best way to run Macs as downloads and maintenance
                            can be carried out over night, I think!
                            Its also a fact that laptops tend to heat up a bit when under
                            pressure, more so than desktops. I thought one way to keep
                            things cool would be to have some control over the fan.
                            I located a utility called Fan Control, it does what it
                            says. Okay if not on mains the battery life is effected but most
                            of my time spent on the laptop when plugged in, so no problem.
                            Also it can be adjusted in on the move.
                            The links for Fan Control, a free application is,
                            http://www.lobotomo.com/products/FanControl/
                            I imagine there is also a free utility for PCs πŸ˜‰
                            Mike
                            PS: Something for the PC laptops,
                            http://www.diefer.de/i8kfan/index.html
