    Can this be modeled in sketchup want a step by step tutorial
    4 Posts 4 Posters 1.1k Views 4 Watching
    • C
      cute90in
      Can anybody give a step by step tutorial for modeling an commercial aircraft with textures or materials applied. I have been trying to model an aircraft. I have attached some images which was created in Illustrator. I want to model this using sketchup.
      Front view of the aircraft
      Right view of the aircraft
      Top view of the aircraft
        rsw
        Yes this can be modelled in su and i'm sure someone could do a brief tutorial for you (I would but I got carried away with trying to model it myself and forgot about the tut altogether)
        You might find this youtube vid by monsterz3r0 of use. (its the first thing I thought of when I saw your post)
        Also you may find this useful (it was going to be a tutorial and not just a model!)
        It was created very similar to the above vid (you should be able to see that the main part of the fusilage is a circle push pulled and then scaled to the correct size, then push pulled again etc etc.
        hope thats of some help.
        Richard
        http://img.userbars.pl/98/19554.png
        http://i158.photobucket.com/albums/t106/671GUAMDUDE/Animated---User-Green.gif
        • I
          ilay7k
          If you have time for it(i look at yt-video), try to model...๐Ÿ˜„
          Skipy has SplineProject, BezPatch, and ect.
          But i prefer cam/cae-tools: rhino/AliasStudioTools, moi/Ayam(free, http://www.ayam3d.org) for it ๐Ÿ˜„
          Good Luck!
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            Yes it can.
            I developped a tutorial made of eigth separate SU files that I posted in the old SU forum a while ago. The problem is that some of the individual files are larger than the 512 K limit on Sketchucation. I will try to upload these on the 3D Warehouse during my Christmas vacation. After that I will post the link here in this forum.
            In the mean time, here is a JPG showing what can be done.
            Just ideas.
