    ๐Ÿซ› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Optimize models
    9 Posts 6 Posters 4.3k Views 6 Watching
      SchreiberBike
      Thanks for the tutorial. I was enjoying it until it stopped at the point below:
        lapx
        I found there are some situations where you might want to keep all faces on a component for instance in doing material take offs you may want to keep all sides of the elements in order for it to be counted, right?
        (lapx)
          Masta Squidge
          I should really work on stuff like this. I already delete any and all geometry that cannot be seen (takes me a while sometimes), but I very rarely use components. I generally make my models as one solid mass.
          • boofredlayB Offline
            boofredlay
            @masta squidge said:
            ... I very rarely use components. I generally make my models as one solid mass.
            Say it isn't so Masta...
            Use your components and your Outliner...
            I would hate to see your sock drawer. ๐Ÿ˜ฎ
              boofredlay
              Because his drawings are so mis-organized his sock drawer would also be.
                Masta Squidge
                Yes it is so... But my models arent usually very large either. I have yet to make a model large enough to slow down my computer at this point. I do a lot of simple stuff. But I DO understand why I would be better off to use them.
                And yes my sock drawer is a mess actually.
                  sketchy
                  Did I miss something? I checked the video a couple of times but didn't see what the end result was. How much file size did all of that work gain?
                    boofredlay
                    ๐Ÿ˜† ๐Ÿ˜† ๐Ÿ˜†
                      That's why I only have two kinds of socks (but a lot of them): you don't need to organise them!
                      ๐Ÿ˜„
