    Exporting to PDF-- image quality problem
    34 Posts 7 Posters 6.8k Views 7 Watching
    • AnssiA
      Anssi
      I had no problem exporting. This is what my Export dialog looked like
      And this is the PDF I got:
      testi.pdf
      Cheers
      Anssi
      • G
        Goggin
        I didn't either!
        But then I figured out what the problem is. I have to use 2D export to get the .pdf option, and in that case it only exports what's visible on the screen. In order for me to get the whole floorplan on the screen, I have to make it much smaller. In that case, you don't get individual lines-- it's like you did a screen capture, and you lose all the detail.
        Try it again with that bathroom floorplan shrunk down like this (don't adjust the magnification):
        Link
        Interestingly, this seems to happen the same way when you use "insert" in LayOut. You only get what's visible on the screen from the .skp file. And if you shrink it down enough to get an entire floorplan (in my case a set of floorplans), you just end up with a blurry image.
        Maybe I'm missing something, but if you can't export to Acrobat at scale, and at 24x36 paper size, then it's not much use in a real-world situation, because that's what's you're going to have to give to builders and city planning depts., etc. I have to believe that this has been worked out, and that I am missing something.
        • GaieusG
          I cannot jump into the discussion now as I'm not at home with my Pro version to export PDF.
          So I just about Gadwin Print screen; you can select the output file type - jpg (as it can be compressed) is the smallest.
          πŸ˜„
          • AnssiA
            Anssi
            Yes, you are missing something. The point of the profile settings is that the "match screen" setting does literally that: the profile line thickness is set in proportion of the screen display, so in your case, if you magnify the plan to four feet wide, the profile thicknesses will follow suit. So you must just untick the "match screen" setting, and decide yourself how wide you want your lines to be. Attached is the setting you probably used
            and the PDF you probably got
            testi1.pdf
            Then my new settings, with all lines at .25 mm thickness
            And the result-see next post, it seems to limit to 3 attachments
            Anssi
            • AnssiA
              Anssi
              And here is the "final" file:
              testi2.pdf
              Anssi
              • G
                Goggin
                [attachment=0:3ba0xxza]<!-- ia0 -->testi2.pdf<!-- ia0 -->[/attachment:3ba0xxza]
                Anssi
                Thank-you, Thank-you, Thank-you!!! That does indeed do the trick.
                I would have never figured that out from just reading the documentation on Exporting in the "Help" section.
                • GaieusG
                  That was a nice one, Anssi, thanks a lot!
                  • G
                    Goggin
                    I hate to bother you guys again about something similar, but I'm still stuck on how to get a high quality floorplan into LayOut. You don't "export" to LayOut, you use the "send to LayOut" command. But there aren't any options to set the linewidths (as there are for the export command), it just sends the file. I've tried changing the quality to 300 DPI in LayOut, but that didn't help. I was hoping to use LayOut to do some text labeling since SketchUp is very limited as to what you can do with text.
                    BTW-- LayOut seems to be a tremendous memory hog, but that's another issue. Just a simple floorplan, to scale, brings my computer to its knees!
                      jhauswirth
                      Don't use 300 dpi in LayOut until you're ready to export to PDF or print, do 72 dpi while you're creating your doc.
                      Line thickness is in the style tab in the Sketchup Inspector. Its in points.
                      So try 0.2.
                      • G
                        Goggin
                        Yeah, I figured that out quick!
                        So try 0.2.
                        Sorry, but what is "SketchUp Inspector"? I did a search for "Inspector" on the help page, and it came up blank.
                        • GaieusG
                          Goggin,
                          That's the "SketchUp Model" tab in your tray. See snapshot (and the lineweight setting input field where my cursor is)
                          http://www.sketchucation.com/forums/scf/sas/Layout/SUInspector.png
                          • G
                            Goggin
                            Oh, that's in LayOut. I was looking in SketchUp. I'll try that later today.
                            • G
                              Goggin
                              Yep, that worked. Thanks, Gaieus.
                              • GaieusG
                                πŸ˜›
                                • 2 / 2
