    Exporting to PDF-- image quality problem
    34 Posts 7 Posters 6.8k Views 7 Watching
    • GaieusG
      Here we have an attachment server:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=77&t=760
      • G
        Goggin
        Thanks, Gaieus. Let's see if this works. Sketch-up floor plan on the left, what the image looks like after export to Acrobat on the right:
        Bathroom Floor Plan
        BTW, I did have those setting correct, Kenny.
        • AnssiA
          Anssi
          You have some funny large value set in the Profile width box. Setting it to Match Screen display is usually enough
          Please don't use the BMP format for image attachments, the file sizes are enormous and they take ages to load
          Anssi
          • G
            Goggin
            Sorry about that. I just used the screen-capture program that Gaieus recommended in an earlier thread: "Gadwin PrintScreen". I guess it defaults to .bmp. Can I still use that and convert to another format that doesn't create such large files?
            I'll fool around with your recommendations, but I'm not quite sure I understand what you're getting at. I set the drawing size parameters so that it would be to scale at 1/4" = 1' in Acrobat.
            • G
              Goggin
              @gaieus said:
              Have you tried to export from LayOut?
              Just tried it. Same result-- bad.
              Anssii: I checked again, and I do have the "Profile Lines" section set to "Match screen display". I'm not sure what the "profile width" box is, though. Did you mean "Drawing Size width" box?
              • AnssiA
                Anssi
                Sorry, my bad memory. Of course I meant the Profile lines box(and Section Lines, too)
                I cannot say right away what the problem is now. I remember once getting the same result, but not what caused it. Let's think about it...
                Well-you say you adjust the page size to get the right scale. For me it works the other way round. I set the scale, and the page size adjusts itself (as I tab out of the scale box). I never touch the page size settings unless I want output that is not to scale.
                Can you attach your skp file?
                Anssi
                • G
                  Goggin
                  Sorry if I didn't make that clear. I set the Drawing Size "scale" parameters* and let the "size" parameters adjust themselves.
                  *This was not easy, though, as SketchUp kept trying to tell me I was exceeding the page size limit. I had to do it in a certain order, or it would reject it.
                  Hmmm. Having trouble doing that. I copied my SketchUp file into the sketchucation newbie folder, but when I click on it, I don't get a URL address to link to-- just and empty (Mozilla) browser page. It worked fine with that .bmp file I did earlier. If you want to look at it, it's in the newbie folder under "Bathroom Floor Plan".
                  • boofredlayB
                    boofredlay
                    Here you go.
                    http://www.sketchucation.com/forums/scf/sas/Newbie/Bathroom%20Floor%20Plan.skp
                    • AnssiA
                      Anssi
                      I had no problem exporting. This is what my Export dialog looked like
                      And this is the PDF I got:
                      testi.pdf
                      Cheers
                      Anssi
                      • G
                        Goggin
                        I didn't either!
                        But then I figured out what the problem is. I have to use 2D export to get the .pdf option, and in that case it only exports what's visible on the screen. In order for me to get the whole floorplan on the screen, I have to make it much smaller. In that case, you don't get individual lines-- it's like you did a screen capture, and you lose all the detail.
                        Try it again with that bathroom floorplan shrunk down like this (don't adjust the magnification):
                        Link
                        Interestingly, this seems to happen the same way when you use "insert" in LayOut. You only get what's visible on the screen from the .skp file. And if you shrink it down enough to get an entire floorplan (in my case a set of floorplans), you just end up with a blurry image.
                        Maybe I'm missing something, but if you can't export to Acrobat at scale, and at 24x36 paper size, then it's not much use in a real-world situation, because that's what's you're going to have to give to builders and city planning depts., etc. I have to believe that this has been worked out, and that I am missing something.
                        • GaieusG
                          I cannot jump into the discussion now as I'm not at home with my Pro version to export PDF.
                          So I just about Gadwin Print screen; you can select the output file type - jpg (as it can be compressed) is the smallest.
                          ๐Ÿ˜„
                          • AnssiA
                            Anssi
                            Yes, you are missing something. The point of the profile settings is that the "match screen" setting does literally that: the profile line thickness is set in proportion of the screen display, so in your case, if you magnify the plan to four feet wide, the profile thicknesses will follow suit. So you must just untick the "match screen" setting, and decide yourself how wide you want your lines to be. Attached is the setting you probably used
                            and the PDF you probably got
                            testi1.pdf
                            Then my new settings, with all lines at .25 mm thickness
                            And the result-see next post, it seems to limit to 3 attachments
                            Anssi
                            • AnssiA
                              Anssi
                              And here is the "final" file:
                              testi2.pdf
                              Anssi
                              • G
                                Goggin
                                [attachment=0:3ba0xxza]<!-- ia0 -->testi2.pdf<!-- ia0 -->[/attachment:3ba0xxza]
                                Anssi
                                Thank-you, Thank-you, Thank-you!!! That does indeed do the trick.
                                I would have never figured that out from just reading the documentation on Exporting in the "Help" section.
                                • GaieusG
                                  That was a nice one, Anssi, thanks a lot!
                                  • G
                                    Goggin
                                    I hate to bother you guys again about something similar, but I'm still stuck on how to get a high quality floorplan into LayOut. You don't "export" to LayOut, you use the "send to LayOut" command. But there aren't any options to set the linewidths (as there are for the export command), it just sends the file. I've tried changing the quality to 300 DPI in LayOut, but that didn't help. I was hoping to use LayOut to do some text labeling since SketchUp is very limited as to what you can do with text.
                                    BTW-- LayOut seems to be a tremendous memory hog, but that's another issue. Just a simple floorplan, to scale, brings my computer to its knees!
                                      jhauswirth
                                      Don't use 300 dpi in LayOut until you're ready to export to PDF or print, do 72 dpi while you're creating your doc.
                                      Line thickness is in the style tab in the Sketchup Inspector. Its in points.
                                      So try 0.2.
                                      • G
                                        Goggin
                                        Yeah, I figured that out quick!
                                        So try 0.2.
                                        Sorry, but what is "SketchUp Inspector"? I did a search for "Inspector" on the help page, and it came up blank.
                                        • GaieusG
                                          Goggin,
                                          That's the "SketchUp Model" tab in your tray. See snapshot (and the lineweight setting input field where my cursor is)
                                          http://www.sketchucation.com/forums/scf/sas/Layout/SUInspector.png
                                          • G
                                            Goggin
                                            Oh, that's in LayOut. I was looking in SketchUp. I'll try that later today.
                                            • 2 / 2
