    Why won't it work?
    17 Posts 4 Posters 2.5k Views 4 Watching
    • GaieusG
      Any links Larry?
      How on (Google) Earth could we know where you put it?
      • Larry BatesL
        Larry Bates
        Hi G,
        Well, I wasn't sure I should upload such a large file. It is ok? I will delete it later.
        Larry
        • GaieusG
          OK, just go ahead.
          Maybe if we really don't need that image there you can delete it from the file (and purge unused materials). If you think you need that image, leave it in there for now.
          • Larry BatesL
            Larry Bates
            Thanks Gaieus,
            I'll do it sometime today.
            Larry
            • Larry BatesL
              Larry Bates
              http://www.sketchucation.com/forums/scf/sas/Newbie/Walts%20model%202.skp
              hope this works. 😐 OK, this should work now G πŸ˜‰
              Thanks.
              Larry
              • GaieusG
                OK,
                So what I tried to do first was to select all (triple click) and choose "Intersect selection" and "Intersect model" several times to fill in the walls but no avail.
                Then - still hoping that all the lines were coplanar" - I made a group of the big face with the image (and its surrounding four edges on the outsides), drew a diagonal line to "triangulate" it then made a group of the rest of the model (all the lines you had drawn) and draped this latter group onto the first one with the use of the sandbox tools.
                Then deleted the remnants of the diagonal line, exploded bboth groups and your walls now seem to be separate faces from the big face.
                Here is the link (once it uploads... πŸ˜’ 😞
                http://www.sketchucation.com/forums/scf/sas/Newbie/Walts%20model%203.skp
                • Larry BatesL
                  Larry Bates
                  Um ok,
                  I don't understand, what does that do? Please don't take this wrong, I don't know how to say it in type without sounding ungrateful. How will this fix help, or is this just the first step?
                  This is not an actual job, so don't feel as you need to give me a quick fix. I am just trying to understand what I am doing wrong. πŸ˜’ ( sorry about the size, next time I'll reduce the size of the scan 😳 )
                  Thanks for taking the time.
                  Larry
                  • GaieusG
                    Larry,
                    I did exactly write down every step I had done because I felt you needed the "way to do" not just the final model.
                    Please, tell me if you don't understand something - I'd be glad to help.
                    • Larry BatesL
                      Larry Bates
                      I'm sorry, I understand what you wrote, I just was wanting to understand what it was I was doing wrong.
                      So, are you saying that because I didn't make the scan of the floor plan a separate layer that the lines were becoming part of it?
                      Modelhead, yes it is a large file, and I will make it smaller, I was trying to get as clear a scan as possible because the print was not that good that I had to work from. Making it gray scale would probably help too.
                      Thanks for your help guys.
                      Larry
                      • GaieusG
                        Larry, layering wouldn't help since layers do not separate geometry in SU only control visibility of them Thus you should never put "primitive" geometry on different layers - group them or make components first and only then put them onto different layers.
                        If you are worrying about your image being split up by the lines, group the image rather than put it on a separate layer.
                        As for the image size; SU "shrinks" your image to something 1024 pixels anyway so loading a bigger image is useless.
                        • AnssiA
                          Anssi
                          Hi Larry,
                          Layers in SU do NOT separate geometry, they are just one way of controlling the visibility of objects. So to keep your lines separate from the scanned photo, you should group it. Grouping or componentizing are the only ways to keep pieces of geometry separate in SU.
                          As to using layers, it is a good practice to draw everything on layer 0, and if you need to use layers, make groups or components of the geometry before moving it to another layer.
                          Anssi
                          • Larry BatesL
                            Larry Bates
                            Gaieus,
                            Ok, smaller image got it. Thanks for your help guys. I'll remove the LARGE FILE now. πŸ˜† and try building again. I hope this is not what I have to do everytime I build something. πŸ˜•
                            Larry
