    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    Old Wooden Barrel
    7 Posts 5 Posters 1.2k Views 5 Watching
      Gidon Yuval
      I was asked by some-one if it is possible to cut an old wooden barrel in half without it falling apart.
      That got me thinking about how I might model a barrel.
      So I gave it a try.
      What do you think?
      An old wooden barrel
      And this is what it would look like if were busted apart.
      Barrel-busted
      Barrel skippy
      If you don't know where you're going, you're never going to get there.
      • boofredlayB Offline
        boofredlay
        Ha Ha. Did you use Sketchy Physics to bust it apart?
          Sawduster
          So, what was the answer to the original question about cutting one in half?
          If the bottom and top of the barrel are left in place, they can surely be cut in half (we've got a pair used as planters in the back yard now). In fact, if the wood has not shrunk and cause looseness in the barrel, should hold alright without the bottom/top in place as long as the rings are intact.
          May all your dimensions be the sum of their total.
          Jerry
          http://www.sawdustersplace.com
          • Joe WoodJ Offline
            Joe Wood
            Here's one that Alan posted on the old @last forum.
            barrel2.skp
            Joe Wood
            woodsshop.com/
              Gidon Yuval
              Oh! Alans barrel is a lot nicer than mine. I just eye-balled the curve and the dimensions. Alan's barrel looks like it's accurately modeled after the real thing. I like the texture too.
              The problem with the way he wanted to cut the barrel was that he wanted it cut in half length-wise, thereby cutting the hoops as well.
              I told him it's possible only if he first screwed each stave to the hoops before cutting and that he'd need to make wooden semi circles for the ends to maintain the shape as the hoops were of very thin metal and when cut would not retain their shape.
              I got an e-mail from him saying that the operation was a success. ๐Ÿ˜Ž
                Sawduster
                Aha, should have figured it would not be as simple as cutting in half as I had assumed.
                Jerry
                  architectboy
                  Here's one that I just made, it's sketchy physics enabled. To bad I cant get the lower rings to stay on.
                  Barrel.skp
