    Converting a model to a solid
    7 Posts 3 Posters 749 Views 3 Watching
      Baker518
      I created a piece that has turned out hollow, NOT solid. How do I make it a solid?
      Thanks....Mike
      Don't worry about things you have no control over. Worry is a lack of Faith!
      • bazB Offline
        baz
        better post the skippy mike. not nearly enough info to comment.
        baz
          Baker518
          Here is the smaller file of the 3.
          Top Connector.skp
          • boofredlayB Offline
            boofredlay
            Mike, SU does not create solid objects. Only the appearance of solid objects. There is a ruby script that will help give the appearance even more called sectioncutface. You can find it here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1517
            Right click on the section plane and select Add Section-Cut Face. It will create a plane at the section.
            Hope this helps.
              Baker518
              That didnt work so great, oh well. It was worth a shot
              Thanks for the help...Mike
                boofredlay
                What did not work? The script or the fact that it is not a solid?
                  Baker518
                  Eric
                  Sorry I didnt get back to you on the solid, but it worked but not the way I wanted it to. I think something like even a hatch of some sort would be ok, but I dont know how to do it.
