    Preparing for SmustardOrganizer script
    56 Posts 11 Posters 8.4k Views 11 Watching
      RickW
      When you download new scripts, they will have to be modified to work with Organizer. The organizerEdit script only looks in the Plugins folder for scripts to edit (so that things that have been edited and organized aren't re-examined).
      So download to the Plugins folder, perform the auto edit, then organize and restart Sketchup.
      I didn't look too carefully at the stair script, just added the appropriate menu lines. It looks like the script has other issues, and unfortunately I don't have time right now to troubleshoot it. Sorry...
      RickW
      www.smustard.com
      • H Offline
        Haggai
        Thank you for your quick reply on that, I imagine that you are busy for the rest of the stuff i asked.
        I will wait maybe someone else had the same problem.
        again thank you.
        [Haggai]
          RickW
          I put the file into a subfolder. It loaded without problems, and it works correctly. I'm not sure why you are gettting the error messages. Is the script in two folders (like Plugins AND 10 French)? Make sure there are no duplicate scripts.
          RickW
          www.smustard.com
          • H Offline
            Haggai
            Rick thank you again for this help,
            so I look and I found the script was there but the english version with a different ruby name, I wanted to have a subfolder with all my french ruby because most of the time the mesurment there are metric, I am french and I work with both metric and Imperial, now i am in the US for a while and all i need to do is imperial but sometime i get some request from france and need to work in metric. Is there a way to have both sets. it seems that the problem is that both script call the same action or something like that and causes a confict somewhere. I don't know anything about ruby script really but i am willing to learn.
            by the way I reorganise the rest of all my script to be organiseable, now one thing i wish to have is the possibility to have all my plugings in one submenu in the context menu like the script TIG made (ContextMenuMenus.rb) he has all the menus (1,2,3,4,5,6,8) he jumped the 7 which is the pluging menu because it is different in each user.
            submenu1=submenus.add_submenu("Edit...") ### adds the submenus for the items that follow
            submenu2=submenus.add_submenu("View...")
            submenu3=submenus.add_submenu("Camera...")
            submenu4=submenus.add_submenu("Draw...")
            submenu5=submenus.add_submenu("Tools...")
            submenu6=submenus.add_submenu("Window...")
            submenu8=submenus.add_submenu("Help...")
            So i wanted to put the 7th submenu in the list. Is there a way that something can be done with organizer.rb to read all that is in the plugins folder and add them to the submenu7 in the context menu ???
            this will be a big plus to your script.
            untill now you have solved all my problems.
            thank you for all your useful scripts
            [Haggai]
              RickW
              You can add a folder name to the SmustardOrganizerExcludeFolders.txt file, and that folder will not be loaded. Or you can add "--" to the front of a folder name and it will not load. This way, you can prevent the metric and imperial from both loading - just exclude the one you don't want to use. When you need to switch, change the excluded folder and restart Sketchup.
              While it is possible to add the whole plugins menu to the context menu, it won't be immediately available with Organizer, but perhaps in a future version I will add that.
              RickW
              www.smustard.com
              • JClementsJ Offline
                JClements
                Hi Rick:
                Couple of questions/requests:
                1. Could you post a screen capture of how a typical "organized" plugin directory would appear?
                2. Is there any way for the organizer script [assuming the Smustard (or any other scripts) were properly annotated] to display the revision number? And, if not the Organizer script, perhaps another similar script,ie., an "About.rb" script, to detect the rev levels?
                3. Would there be a method for the users to control the order of scripts within a folders (short of renaming them) or is this still controlled by SU as it loads the scripts into memory?
                Regards, John
                JClements at brwncald daught com
                  RickW
                  1. Well, I think it's up to the individual user, but I created the following folders:
                  • Cameras-Pages
                  • Draw-Create
                  • Edit-Modify
                  • Export-Import
                  • Selection
                  • Textures-Materials
                    There are items not in folders, but I think the majority are categorized.
                  1. The annotation part is the key. I could try to create something like that, but my guess is that it would be rather "iffy". For Smustard scripts, a quick trip to MySmustard (via the Smustard Toolbar) will give you a synopsis of the last script version you downloaded, compared to the version currently available.
                  2. I think it's still controlled loosely by SU and/or the OS. Organzier could load things alphabetically by sorting the directory list before loading, but that's about the extent of it. It would be possible to create a text file that indicates the order to load scripts, but I think that would be prone to problems if things got moved or deleted. I'll think about how that might be implemented and see if it could be workable.
                  RickW
                  www.smustard.com
                    JClements
                    Thanks, Rick
                    • N Offline
                      not registered yet
                      Rick,
                      Maybe I'm just not getting it today, but I have followed the instructions given for Organizer and keep getting this message when I run organizerEdit.txt from the Ruby console.
                      organizerEdit.txt
                      Error: #<NameError: (eval):196: undefined local variable or method `organizerEdit' for #Object:0xe8a6880>
                      (eval):196
                      If I go ahead and add my folders, they show on the plugins menu, but don't do anything. And the original plugins are still listed as before!!?
                      Any idea what's going on?
                      [TonyF]
                        RickW
                        Rather than typing
                        organizerEdit.txt
                        you need to type
                        load "organizerEdit.txt"
                        Hope that helps...
                        RickW
                        www.smustard.com
                        • N Offline
                          not registered yet
                          organizerEdit.txt ran okay, but I didn't get a log file.
                          Further, when I create a sub folder under plugins, it shows on the Plugins menu drop down, but any files I put in that folder are listed underneath it, not inside it?
                          [TonyF]
                          • N Offline
                            not registered yet
                            Rick,
                            I'm still not having much success 😞
                            "organizerEdit.txt" seems to run okay - i.e. the Ruby conole shows no errors, but no log file is produced.
                            If I add a new sub-folder to the plugins folder, it does not show in the Plugins menu until I put a ruby file in the new folder. Even then, the ruby that I have just put in to the sub-folder, does not show up as a sub-menu item, but is listed below the new sub-menu item on the main Plugins menu drop down.
                            Confused ?? That make two of us 😄
                            Any ideas??
                            [TonyF]
                              RickW
                              It sounds like the .rb files didn't get edited. Please contact me through Smustard so we can email back and forth. I would like to see some of the files that are giving you problems.
                              RickW
                              www.smustard.com
                                RickW
                                I finally restructured Organizer. This adds a troubleshooter and OrganizerEdit into a Tools>Organizer menu item.
                                RickW
                                www.smustard.com
                                • jujuJ Offline
                                  juju
                                  let us know when you're letting it into the wild
                                    RickW
                                    I am updating Organizer again. The main change is for accommodating plugins that have subfolders for required files.
                                    The update provides a mechanism for developers to easily exclude their subfolders so Organizer will not try to load the contents of those folders. This should result in a smoother experience for users, who won't have to contend with manually maintaining the excluded folders list in the SmustardOrganizerExcludeFolders.txt file.
                                    Developers: in your subfolder, create a text file called "exclude.txt" that has as its contents the plain text name of the subfolder - that's it! You can use the attached file and change "myFolderName" to your subfolder's name if you want.
                                    The new version should be available starting Monday (14 Sept 2009).
                                    exclude.txt
                                    RickW
                                    www.smustard.com
                                      RickW
                                      Organizer 1.4 is now available.
                                      To update to Organizer 1.4, you have three possible options:
                                      1. Use the download link you previously received when you purchased your license. If you don't have it, then
                                      2. Use the "MySmustard" button on the free Smustard Toolbar. Register using the email address provided when you purchased your license. If you don't have that account, or if you just don't want to install the Smustard Toolbar (which also gives you access to relevant upgrade offers), then
                                      3. Email me and I'll hunt down your information. If too many need/choose this option, my response may be delayed, and I may need to come up with an alternative method.
                                      RickW
                                      www.smustard.com
                                      • 3 / 3
