    Preparing for SmustardOrganizer script
    56 Posts 11 Posters 7.5k Views 11 Watching
    • JClementsJ Offline
      JClements
      Thanks, Rick
      • N Offline
        not registered yet
        Rick,
        Maybe I'm just not getting it today, but I have followed the instructions given for Organizer and keep getting this message when I run organizerEdit.txt from the Ruby console.
        organizerEdit.txt
        Error: #<NameError: (eval):196: undefined local variable or method `organizerEdit' for #Object:0xe8a6880>
        (eval):196
        If I go ahead and add my folders, they show on the plugins menu, but don't do anything. And the original plugins are still listed as before!!?
        Any idea what's going on?
        [TonyF]
          RickW
          Rather than typing
          organizerEdit.txt
          you need to type
          load "organizerEdit.txt"
          Hope that helps...
          RickW
          [www.smustard.com](http://www.smustard.com)
          • N Offline
            not registered yet
            organizerEdit.txt ran okay, but I didn't get a log file.
            Further, when I create a sub folder under plugins, it shows on the Plugins menu drop down, but any files I put in that folder are listed underneath it, not inside it?
            [TonyF]
            • N Offline
              not registered yet
              Rick,
              I'm still not having much success 😞
              "organizerEdit.txt" seems to run okay - i.e. the Ruby conole shows no errors, but no log file is produced.
              If I add a new sub-folder to the plugins folder, it does not show in the Plugins menu until I put a ruby file in the new folder. Even then, the ruby that I have just put in to the sub-folder, does not show up as a sub-menu item, but is listed below the new sub-menu item on the main Plugins menu drop down.
              Confused ?? That make two of us 😄
              Any ideas??
              [TonyF]
                RickW
                It sounds like the .rb files didn't get edited. Please contact me through Smustard so we can email back and forth. I would like to see some of the files that are giving you problems.
                RickW
                  RickW
                  I finally restructured Organizer. This adds a troubleshooter and OrganizerEdit into a Tools>Organizer menu item.
                  RickW
                  • jujuJ Offline
                    juju
                    let us know when you're letting it into the wild
                      RickW
                      I am updating Organizer again. The main change is for accommodating plugins that have subfolders for required files.
                      The update provides a mechanism for developers to easily exclude their subfolders so Organizer will not try to load the contents of those folders. This should result in a smoother experience for users, who won't have to contend with manually maintaining the excluded folders list in the SmustardOrganizerExcludeFolders.txt file.
                      Developers: in your subfolder, create a text file called "exclude.txt" that has as its contents the plain text name of the subfolder - that's it! You can use the attached file and change "myFolderName" to your subfolder's name if you want.
                      The new version should be available starting Monday (14 Sept 2009).
                      exclude.txt
                      RickW
                        RickW
                        Organizer 1.4 is now available.
                        To update to Organizer 1.4, you have three possible options:
                        1. Use the download link you previously received when you purchased your license. If you don't have it, then
                        2. Use the "MySmustard" button on the free Smustard Toolbar. Register using the email address provided when you purchased your license. If you don't have that account, or if you just don't want to install the Smustard Toolbar (which also gives you access to relevant upgrade offers), then
                        3. Email me and I'll hunt down your information. If too many need/choose this option, my response may be delayed, and I may need to come up with an alternative method.
                        RickW
                        • 3 / 3
