    Component composed of components?
    5 Posts 4 Posters 1.5k Views 4 Watching
    • N
      not registered yet
      The component function in make component is sometimes broke. The big components make the name component menu not work. the component name menu just doesnt show up. I think it has something to do with component inside the component. Can components be made of components?
      P: Insipidus
      • KrisidiousK
        Krisidious
        yes they can... I have also noticed that sometimes the dialog box does not come up, but if you repeat normally it has to do with something already being in a group.
        By: Kristoff Rand
        • TaffGochT
          TaffGoch
          You can view a listing of components and any components contained within:
          Open the 'Model Info' dialog box, and select 'Statistics' from the left-hand column. Select 'Only components' from the right-hand drop-down list. Also check the box 'Show nested components'
          (And there's your SketchUp terminology -- 'Nested' components.)
          You can obtain similar results with the 'Outliner' window.
          Regards,
          Taff
          "Information is not knowledge." -- Albert Einstein
          • N
            not registered yet
            ah..the hidden features of SketchUp...well I just about exploded the entire drawing before I had it makin a component. Hope I have backed up lately.
            thanks
            P: Insipidus
            • boofredlayB
              boofredlay
              Or you can just use the Outliner to see all your components/nested components.
