    Floating Dialog menu disappeared
    4 Posts 2 Posters 1.1k Views 2 Watching
      rhankc
      Actually all of the disappeared. I can bring up new ones like Fog and Photomatch, But My Layer, Scene, Outliner, Components, materials & styles have disappeared. I think this was a vid card issue, and I have set my resolutions down low hoping to find them in the margins, but now I am out of ideas. Anyone seen this before.
      If they are out there somewhere there should be a default SU command to retrieve them and make them redock to HOME. But that is probably just a wish.
      I did get one of them to return, I right clicked on one of the new ones I brought up, clicked restore and move and Wntity Info came back to the screen. Unfortunately this isn't working on the others.
      This happen when my screen res was high, and I thought maybe I could get the menus turned off and reboot, but , the Window Mneu shows a hyphen beside the floater name or a checkmark: no turning it off, I guess because its out of site?
      If anyone else gets into this here is the answer: viewtopic.php?f=22&t=683&hilit=lost+windows
      whew....
      Hank
        Hank, in that other thread the guys had multiple monitors. Is that the same with you?
        If not, try to adjust your window smaller (not "full screen" - maybe the dropdown windows got stuck somewhere underneath/behind the main window.
          rhankc
          yes same with me. couldn't live w/out them. Thanks
          Hank
            Than I'm sorry but the problem might be more complicated than what I could answer for I only have one (working - and two old, broken ones in the attick but I don't think any of my dialogues could hide there...)
