    Hourglass on Right Click
    15 Posts 6 Posters 7.1k Views 6 Watching
      Now this is really weird indeed. If you don't mind, I'll have a look at your profile in the admin panel (I cannot see your bank account details or your pasword there πŸ˜„)
      With the mouse you must be right. I have a Logitech mouse but I have uninstalled its special driver for it was not compatible with SU. I'm now just working with basic functions.
        sorgesu
        Fine, fine, now let's discuss something really important. Am I not CUTE!! im my picture. Oooh how adorable I am.
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
          Stu
          Yes, very cute Susan!
          Do you still wear your hair like that?
          Stu [yep the same one πŸ˜„]
          http://www.landesign.com.au
            sorgesu
            Hey Stu. Nice of you to drop in. My hair isn't quite that curly anymore. But most days I look just like that. No hair brush and dressed in PJs and bathrobe. Ah the pleasures of working from home.
            Susan Sorger
              Thanks Stu for telling. Otherwise there could have been some minor confusion when attributing the posts.
              πŸ˜’
                sorgesu
                Actually I am still having this problem. I read on the web that it has to do with non-Microsoft shell extensions in the registry. I was supposed to disable all of them and then enable one by one to find which one is causing the problem. Well I disabled all of them and I was still having the problem so I reckon the issue is NOT the shell extensions.
                Anyone else have any ideas.
                The problems started in mid October. I don't recall if I had downloaded or added or made any particular changes at the time. I was travelling and I noticed it in my hotel room. Any ideas would be much appreciated.
                Susan Sorger
                  Try a full virus check. But it might be something that even a good virus checker fails to spot like ye olde 'nashi-worm' ? You can catch all sorts of things in hotels....
                    sorgesu
                    Well that's not very encouraging. How do I find it if Norton can't?
                    Would that be the only thing that such a virus would be interested in doing? In other words, do you really think it is likely to be a virus? Or something that I must have done??
                    Susan Sorger
                    • AnssiA Offline
                      Anssi
                      Susan,
                      At work I have one computer with the same problem. The right-click menu takes more than a minute to appear.
                      To me the reason seems to be that the company network had a radical change, and as this particular machine was left to the old configuration for some backward compatibility, every nook and cranny of its brain is filled with references to network drives and locations that do not exist any more. The rest of our hardware was either upgraded or reinstalled from scratch.
                      After messing around with it, I noticed that the problem persists with only the old user accounts. With a new user account "local" to the machine, everything works OK. I have no option to use a registry cleaner, but it seems to me that a good such might be able make things better. You might try if the problem persists wih a new or different user account.
                      Anssi
                        sorgesu
                        sounds like it is worth a try. Thanks Anssi.
                        Susan Sorger
                        • W Offline
                          watkins
                          Dear Susan,
                          You mention that your hard-drive is pretty full. When running 'Disk Cleanup' did you select 'compress old files'? If you go to 'Windows Explorer' and select 'My Computer' in the address box, then 'Local Disk(C:)' should be in black. If it is in blue then your C drive has been compressed. Windows decompresses compressed files on the fly, which can take time.
                          I think the solution is to mirror copy of everything onto a hard-drive with more capacity and then decompress the C drive. It sounds like you could do with more capacity anyway.
                          Kind regards,
                          Bob
                            sorgesu
                            Thanks so much Bob. But it would appear that the πŸ˜„ drive is black and uncompressed so thtat doesn't seem to be the reason.
                            Anssi, I think you are on to something. I created another user and signed on with that and when I selected a bunch of files and right clicked there was a marked difference in the hesitation time for the context menu to show up.
                            Now I don't really want to use the new user ID because I would have to set up all the program icons all over the palce all over again.
                            But now the question is, what is it in my user profile that is causing the slow down?
                            Susan Sorger
