    Does anyone remember?
    12 Posts 5 Posters 11.1k Views 5 Watching
    • F
      Francois
      I think I remember the solution being uninstalling Sketchup and then reinstalling.
      yes
      Can I just trash the application and leave everything else (plists, component lists, etc) and then just use the new application?
      yes
      Where can I download the application again?
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      Francois
      • GaieusG
        Do I sign up for another 8 hour trial version and then use my existing serial number? Do I have to contact Sketchup support?
        I guess I am using version 5 to do this right now...
        If you are using v5 then here's the info about the upgrade:
        http://www.sketchup.com/cgi-bin/store/upgrade6/index.html?id=MCApSGiB
        • C
          colinpartridge
          I know this was discussed here a few weeks ago.
          I usually use 3DS but thought I would try a fbx and it is not on the list anymore.
          Wasn't there someone who no longer had FBX export as a 3D model export choice on their Mac?
          There is no need to reinstall SU all you should have to do is start SU using Rosetta, however I think that maybe FBX has been removed completely from recent builds...this worked on build 6.0.313 but not on build 6.0.1145.
          Colin (colinpartridge)
          • GaieusG
            The Windows version has fbx export option If you want, I can give it a try (you can send me an email with an 1mb attachment from the link in my signature)
            • F
              Francois
              One should read the release notes for SU 6.0.1145 for Mac here : http://docs.google.com/View?docid=ajg9d7mmp8rt_5dfz7c6
              it is clearly indicated :
              " If you upgrade to a non-English release after installing an English SketchUp 6 release. the FBX exporter may not longer be available on the Mac. The workaround is to uninstall the release and then reinstall the non-English release. "
              I am running an English version . Had the same problem. Reinstalled 6.0.1145. Fixed !
              Francois
              • C
                colinpartridge
                Good call Francois, however since I am running the English version I saw no reason to pay any attention to this ( I haven't used fbx for sometime).
                Colin
                colinpartridge
                • O
                  otb designworks
                  Thanks guys. I never have installed a non-english version but still no fbx export.
                  Thanks for the Francois, hopefully I can get this thing working.
                  kannonbal
                  Cheers, Chuck
                  OTB Designworks is on Youtube
                  • O
                    otb designworks
                    Good news and bad news.......
                    Good news is the FBX export option is now available after reinstall!! Thanks Francois for that.
                    Now, however, 3DS export is non-functioning. When I choose 3DS as my export option and click the OPTIONS button, I get no window popup. Sketchup just sits there waiting for me to hit EXPORT. If I do hit EXPORT without attempting to change anything, I get the progress window, but it never starts the export. I get that blue/white barber's pole that indicates that it is thinking about it but a progress bar never starts and a file never shows up.
                    I tried trashing my plist to no avail.
                    This wouldn't be that big a deal to me except that VUE won't accept FBX files and it won't accept mac SKP files either, though it takes windows32 SKP files no problem.
                    This is so annoying.................
                    kannonbal
                    Cheers, Chuck
                    • C
                      colinpartridge
                      I experienced a bit of 3ds funkiness after reinstalling the 6.0.1145 build again, but after throwing away the "com.google.sketchuppro.plist" it all seems to be working as it should be.
                      colinpartridge
                      • O
                        otb designworks
                        Well, I trashed every Sketchup plist, trashed the program again, and reinstalled.
                        Everything seems to be behaving (knock wood)
                        Thanks for the help, guys
                        kannonbal
                        Cheers, Chuck
