    Sketchy Physics Contest
    33 Posts 11 Posters 8.9k Views 11 Watching
    • KrisidiousK
      Krisidious
      this is the kind of stuff I was talking about Chris... testing shapes and systems... now make glue for me... and sand and water and wind and... and... yeah I know, I'm really happy to just have this.... but I can still wish...
      By: Kristoff Rand
        architectboy
        Thanks for showing me what "convexhull" does, with that info I have revised it again.
        ArchitectBoyBridge.skp
        • C
          CPhillips
          Very nice! It looks elegant and its really stable. I vote for this one. πŸ˜„
          • C
            CPhillips
            Ok, so I'm playing around with my bridge destroying it, throwing the car around, etc. when I come up with the idea of rendering the bridge, and once I had a nice render of it I couldn't help but make one of it destroyed πŸ˜„ .
            These renders are pretty sweet. I assume it is Kerkthea?
              architectboy
              Yep, that's Kerkythea (you forgot the y). Are you working on yours, CPhillips?
              • C
                Charlie__V
                Convexhull:
                Is this simply a cube (re-assinged to covexhull)and the form adjusted as necessary?
                Forgive me if I have missed something obvious.
                C
                • C
                  CPhillips
                  Convexhull:
                  C
                  It doesnt have to be a cube. Any shape will work. The easiest way to imagine a convex hulled object is to picture it wrapped in plastic. Here is a more detailed explanation:
                  http://www.rustycode.com/tutorials/convex.html
                  If you want to see what the physics engine thinks an objects shape is:Right click the object and select Debug->Readback Collision Geometry. Then press play.
                  • C
                    Charlie__V
                    Chris,
                    Thanks for the info....and Thanks for a Really Cool Script :~)
                    C
                    • W
                      Will03
                      Hey guys,
                      This is my first time using this script, and I think i might not be adhering to all the rules of the program, but nonetheless here is my submission.
                      Thank you for this great program! I love it!
                      Will03Bridge.skp
                        architectboy
                        The problem with your bridge is that it uses 18 static parts (see rule #3) which make it impossible to tear down the bridge (try it), those parts are the joints. Joints, by default, are static, but if you make them not static they just fall. So you must leave them static and group them with one of the objects that it is connected with. Just take a look at this revision of your bridge.
                        Will03BridgeLegal.skp
                        • W
                          Will03
                          oh cool, thanks for the hand! that makes a lot of sense now... I'll have to make a bigger and better bridge now...
                            architectboy
                            Go for it! and that goes for anyone else who wants to build a bridge for this contest.
                            • C
                              CPhillips
                              Not quite the same thing. But this guy did a bridge! πŸ˜„
                                SpaceCow
                                Hey, was wondering if this was a legitimate bridge. There are hinge joints inside the triangular prism blocks... They are attached to a couple of things to simulate being attached to another piece(s). I could make the whole bottom a box, but that's not accurate.
                                bridge.skp
                                • L
                                  LilDood
                                  My entry, only hinges, witchcraft πŸ˜„
                                  Witchcraft
                                    Julius
                                    so, basically, the first one is the best, but i think it infringes the rule about the large scale grouping, while the second one shouldn't. the second it's bad looking but it works.
                                    anyway, i'm not an advanced user of scketchup, maybe i'll try a better bridge later.
                                    someone can tell me why in the second one a grouped object takes off?
                                    SketchyPhysicsBridge-by_Julius.skp
                                    SketchyPhysicsBridge-by_Julius_2.skp
                                      Julius
                                      is there anybody out there?
                                        architectboy
                                        Nope, nobody was out there. But now that I'm back...
                                        The reason that you're bridge section moves is that convex-hull is convex, like it's been shrink wrapped. The only way that I could get around that was to make each individual line of the inside curve a different object, then group them all.
                                        By the way, you can forget about the rules if you want. Just make your bridge cool and breakable.
                                          Julius
                                          thank you! now we can make cool things with the new version of SP!
                                            jFerg
                                            I realize I missed out on the timing for this a little bit, but I just discovered Sketchy Physics (which is amazing) and I desided to add my bridge up here. I believe it is the first suspension bridge. It moves terrible slow because the number of joints and groups, but check it out.
                                            Suspension Bridge.skp
                                            • 2 / 2
