    Sketchy Physics Contest
    33 Posts 11 Posters 8.9k Views 11 Watching
      architectboy
      Wow... what a balancing act... I like it... To bad it violates rule #1, but otherwise I like it. And I revised mine, it looks a lot better now.
      ArchitectBoyBridge.skp
      • C
        CPhillips
        FYI, You can make perfect arches if you use the convex hull shape. Here is an example:
        arch1.skp
        • KrisidiousK
          Krisidious
          this is the kind of stuff I was talking about Chris... testing shapes and systems... now make glue for me... and sand and water and wind and... and... yeah I know, I'm really happy to just have this.... but I can still wish...
          By: Kristoff Rand
            architectboy
            Thanks for showing me what "convexhull" does, with that info I have revised it again.
            • C
              CPhillips
              Very nice! It looks elegant and its really stable. I vote for this one. πŸ˜„
              • C
                CPhillips
                Ok, so I'm playing around with my bridge destroying it, throwing the car around, etc. when I come up with the idea of rendering the bridge, and once I had a nice render of it I couldn't help but make one of it destroyed πŸ˜„ .
                These renders are pretty sweet. I assume it is Kerkthea?
                  architectboy
                  Yep, that's Kerkythea (you forgot the y). Are you working on yours, CPhillips?
                  • C
                    Charlie__V
                    Convexhull:
                    Is this simply a cube (re-assinged to covexhull)and the form adjusted as necessary?
                    Forgive me if I have missed something obvious.
                    C
                    • C
                      CPhillips
                      Convexhull:
                      C
                      It doesnt have to be a cube. Any shape will work. The easiest way to imagine a convex hulled object is to picture it wrapped in plastic. Here is a more detailed explanation:
                      http://www.rustycode.com/tutorials/convex.html
                      If you want to see what the physics engine thinks an objects shape is:Right click the object and select Debug->Readback Collision Geometry. Then press play.
                      • C
                        Charlie__V
                        Chris,
                        Thanks for the info....and Thanks for a Really Cool Script :~)
                        C
                        • W
                          Will03
                          Hey guys,
                          This is my first time using this script, and I think i might not be adhering to all the rules of the program, but nonetheless here is my submission.
                          Thank you for this great program! I love it!
                          Will03Bridge.skp
                            architectboy
                            The problem with your bridge is that it uses 18 static parts (see rule #3) which make it impossible to tear down the bridge (try it), those parts are the joints. Joints, by default, are static, but if you make them not static they just fall. So you must leave them static and group them with one of the objects that it is connected with. Just take a look at this revision of your bridge.
                            Will03BridgeLegal.skp
                            • W
                              Will03
                              oh cool, thanks for the hand! that makes a lot of sense now... I'll have to make a bigger and better bridge now...
                                architectboy
                                Go for it! and that goes for anyone else who wants to build a bridge for this contest.
                                • C
                                  CPhillips
                                  Not quite the same thing. But this guy did a bridge! πŸ˜„
                                    SpaceCow
                                    Hey, was wondering if this was a legitimate bridge. There are hinge joints inside the triangular prism blocks... They are attached to a couple of things to simulate being attached to another piece(s). I could make the whole bottom a box, but that's not accurate.
                                    bridge.skp
                                    • L
                                      LilDood
                                      My entry, only hinges, witchcraft πŸ˜„
                                      Witchcraft
                                        Julius
                                        so, basically, the first one is the best, but i think it infringes the rule about the large scale grouping, while the second one shouldn't. the second it's bad looking but it works.
                                        anyway, i'm not an advanced user of scketchup, maybe i'll try a better bridge later.
                                        someone can tell me why in the second one a grouped object takes off?
                                        SketchyPhysicsBridge-by_Julius.skp
                                        SketchyPhysicsBridge-by_Julius_2.skp
                                          Julius
                                          is there anybody out there?
                                            architectboy
                                            Nope, nobody was out there. But now that I'm back...
                                            The reason that you're bridge section moves is that convex-hull is convex, like it's been shrink wrapped. The only way that I could get around that was to make each individual line of the inside curve a different object, then group them all.
                                            By the way, you can forget about the rules if you want. Just make your bridge cool and breakable.
