    Free open-source tool that opens your .skp and gives you a cut list (I'm the author, looking for testers)
    27 Posts 2 Posters 1.2k Views 2 Watching
    • B
      boardfoot Newcomers
      @pilou thank you. On the waits in big files: which step is slow for you, opening the file, turning the view, or a Move of a group or a component?
      If you can say roughly how big the model is (how many groups and components, or the size of the .skp), that tells me where to look. Moving many curves got much faster in 0.1.0-alpha.7, so the version matters too.
        something like
        a group with an object with 3 edges filleted
        then 1 0 copy rotations
        group all
        then 10 copy rotations
        group all
        group all
        Group all
        Then 10 copy move
        thing slow is the calculate! ๐Ÿ™‚
        But i have an old one computer more 13 years old! ๐Ÿ™‚
        • B
          boardfoot Newcomers
          @pilou thank you, that is clear: one rounded part, ten of it, ten of those, and so on. Five levels of ten is 100,000 copies of the part.
          Your old computer is not the only reason. Sawhorse is slow there on a recent desktop PC too. It was measured here with a small box with three rounded edges (42 faces):
          • Up to 1,000 copies, a copy step takes about a second or less.
          • The step from 1,000 to 10,000 copies takes 20 to 30 seconds, and moving the whole thing afterwards about 28 seconds.
          • The last step, to 100,000, is refused: the model may hold 100,000 groups and component copies, and this one would hold 111,110.
          • With 10,000 copies in groups, Save is refused as well, because the file would be too big. Nothing is lost when that happens, but the model cannot be saved as it is.
          Why: every copy of a group is a full solid of its own, and after each step the whole model is checked and drawn again. And nothing on screen says that it is working.
          Two things make it lighter:
          • Make each level a component (Make Componentโ€ฆ) in place of a group. With 10,000 copies the copy step took about 10 seconds where groups took 22, moving everything took 6 seconds where groups took 28, and the file saved (11 MB). Making the component itself takes a few seconds at that size.
          • Type the count once after the first copy (x9 gives nine more) and do not copy nine times by hand.
          What was found is written down:
          • https://github.com/sawhorse3d/sawhorse/issues/142 (moving and copying groups inside groups)
          • https://github.com/sawhorse3d/sawhorse/issues/143 (a model too big to save)
          • https://github.com/sawhorse3d/sawhorse/issues/144 (no sign that an edit is running)
          One question: Sawhorse has no fillet tool, so here the edges were rounded with arcs and Push/Pull. How did you round yours, in Sawhorse or in a .skp that you opened?
            I have confused with another one! ๐Ÿ™‚
            So you can avoid the fillets inside your calculate! ๐Ÿ™‚
            replace it by a simple circular hole!
            • B
              boardfoot Newcomers
              @pilou no harm done, and thank you for saying so.
              The recipe was worth measuring anyway: the three things it found are real, with or without fillets. A part with one round hole has nearly as many faces as the rounded one, so the waits should be much the same. That one was not measured here.
                Yep but i have not this slow impression with some of your challengers! ;
                Above 5 level yes! ๐Ÿ™‚
                alt text
                • B
                  boardfoot Newcomers
                  @pilou fair point, and your recipe is what found it. The slowdown with groups inside groups is fixed on main since last night.
                  Measured on one desktop PC with the same small rounded part, 10,000 copies in nested groups: moving the whole thing takes about 4.5 seconds where it took 23, and copying it about 4.6 seconds where it took 33. The groups themselves now cost almost nothing. What is left is the 10,000 parts.
                  The app in the browser at https://sawhorse3d.com/app is built from main, so it has the fix. The desktop download does not.
                  Two things your recipe found are as they were: a model that large can be too big to save (https://github.com/sawhorse3d/sawhorse/issues/143), and nothing on screen says a long edit is running (https://github.com/sawhorse3d/sawhorse/issues/144). The fifth level, 100,000 copies, is still refused.
                  Thank you for the recipe.
