    SU 2027 Update with Non-Working Fredo Collection
    2 Posts 2 Posters 8 Views 2 Watching
    • T
      trainman2001
      Whenever I upgrade SU (Studio Version) something doesn't work. In this case it's Fredo. I have Curviloft, Corner, Scale, Tools and Library. The icons are on the screen, but do nothing. I uninstalled them all and then did a fresh reload from Sketchucation. Same situation! When I try to activate them, I get this error.
      And I have absolutely no idea of what to do with this. I could use some help.
        What OS are you using ?
        How did you install and then run SketchUp ?
        Do you have the latest version of the SketchUcation tools installed ?
        This contains the newest licensing files.
        Do you also have the latest versions of LibFredo6 and the extensions,
        AND have you restarted SketchUp after the installations to sync everything ?
        Open Window > LibFredo6 Settings... > Fredo6 Plugins Information for SketchUcation Support
        And a report appears in the Ruby Console.
        Select all [Cmd+A ?] and Copy it, then Paste it into a reply in this thread...
