    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 90.1k Views 55 Watching
      Archimars
      Le message d'erreur en question dans la console ruby :
      2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:3010:in `block in change_current_material'
      Error: #<NoMethodError: undefined method `window_get_window' for G6B:Module
      Did you mean?  window_get_title>
      c:/users/apt201080/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6webcursor.rbe:117:in `block in compute_sub_handle'
      c:/users/apt201080/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6webcursor.rbe:116:in `each'
      c:/users/apt201080/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6webcursor.rbe:116:in `compute_sub_handle'
      c:/users/apt201080/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6webcursor.rbe:105:in `block in create'
      • fredo6F
        It seems that the loading of LibFredo6 does not execute well (the binary does not load).
        Could you use the menu entry Window > LibFredo6 settings... > Fredo6 Plugins Information for Sketchucation Support and post the output here. This is to have the details on what is loaded.
        Anyway, this has nothing to do with the license a priori.
        A 1 Reply Last reply
          Archimars @fredo6
          @fredo6
          It is working well now, probably fixed when I restarted my computer ! thanks !
          • fredo6F
            NEW RELEASE: ThruPaint v2.9a - 21 Apr 26
            Requirements:
            • >= LibFredo6 15.9b
            ThruPaint 2.9a is a release including:
            • bug fixing
            • Future compatibility
            Home Page of ThruPaint for information and Download.
            Main post of this thread.
            • L
              Layer One
              Is there any documentation or videos that explain how Paint Objects works? I can't get it do work.
              • fredo6F
                No written documentation. You have some help within the application. There are also many videos out there.
                L 1 Reply Last reply
                • L
                  Layer One @fredo6
                  @fredo6 Thank you. Maybe you can help. I'm trying to paint various groups or components with components using the Paint Objects tool, but not matter what I do, nothing happens.
                  • B
                    bsfranza
                    Hi there, i would appreciate if there was an option to start directly without the initial popup of the material browser.. for me its always laggy and i cant get used to it... the top bar is enough for me ... so one vote up for a option to disable the material browser πŸ™‚
                    Other than that a amazing Plugin and well worth the price and love
                    fredo6F 1 Reply Last reply
                    • fredo6F
                      fredo6 @bsfranza
                      Unfortunately, this would require some heavy re-engineering of ThruPaint. Normally, you get it once by Sketchup session, so it's just a smaller inconvenience.
                      • T
                        talleycl1994 Newcomers
                        I am having issues when I try to open Thrupaint where it is just showing a blank dialogue box. How do I fix this? I made sure both Thrupaint and Fredo6 are the most up to date. I am using Sketchup 2026 on a 2021 MacBook Pro M1 Max.
                        Fredo6 Plugins Information on 2026-09-11 11:55:52 -0400
                        • Platform: arm64-darwin - Ruby: 3.2.2
                        • Sketchup: 26.1.257
                        • LibFredo6: v16.1a
                        • LibFredo6 Binary NOT loaded
                        • Sketchucation Tools: 5.0.7
                        • SCFLicense: v7.3b - 72
                        • Fredo6 Plugins
                          JointPushPull v4.9a
                          Pic2Shape v1.3a
                          RoundCorner v3.4a
                          ThruPaint v2.9a - licensed FULL: 193628 - FJ1781843308.0G
                          Signature File: 2026-06-19 00:28:28 -0400
                          ThruPaint: 2026-06-30 10:31:33 -0400
                        • fredo6F
                          There is a problem with a binary file in SU2026 on Mac
                          Could you try with LibFredo6 v16.1g, just published.
                          After installation and restart of Sketchup, please do a Window > LibFredo6 Settings... > Fredo6 Plugins Information for Sketchucation Support.
                          At the top in the output of the Ruby Console, tell me if you see binary loaded or Binary NOT loaded.
                          Also, it would be good to upgrade to Sketchucation Tools v5.0.8, although this is not related.
                          • 10 / 10
