    [Plugin][$] FredoPortrait - v2.9a - 01 Apr 24
    86 Posts 24 Posters 135.9k Views 24 Watching
    • fredo6F
      @rv1974 said:
      Fredo, 'generate 2d component' tool produced slightly larger 2d representation* of original one (for example 3969mm instead of 3967mm). is there possibility to make it precise?
      *- parallel projection of course, anycontouring mode
      Would you have a model to investigate. I am not sure however that the plugin can do anything about the Sketchup inherent precision.
        rv1974
        please take a look
        Group_23.skp
          rv1974
          another issue: some parts in 2D component get lost
          Group_1.skp
          • cmeedC
            cmeed
            Hi Fredo,
            I have a few problems using Portrait Studio
            When its open, SU looks like it jumps back a few steps. if i click into a group with Portrait open it will jump back to what ever happen a few moments ago - if I rotated , altered position or placed an object
            Please see you personal messages and the dropbox link to the movie i just took
            Cheers
            C
            • fredo6F
              NEW RELEASE: FredoPortrait v2.8a - 25 Dec 22
              Requirement:
              • LibFredo6 13.6a
              • Sketchucation ExtensionStore v4.2.9
              FredoPortrait 2.8a is for extension of validity
              Home Page of FredoPortrait for information and Download.
              Main post of this FredoPortrait thread.
              M 1 Reply Last reply
                mbieniu1 @fredo6
                @fredo6
                Hello,
                Is it now possible to batch export files to PDF (in the case of vectors)? I'm looking for an extension for bulk export of PDF files by tags or scenes.
                • fredo6F
                  NEW RELEASE: FredoPortrait v2.9a - 01 Apr 24
                  Requirement:
                  • LibFredo6 14.3b
                  • Sketchucation ExtensionStore v4.4.0
                  • Sketchup SU2017 and SU2018 for some functions
                  FredoPortrait 2.9a is a maintenance release for:
                  • Future compatibility
                  • P
                    pierrearchi26
                    This post is deleted!
                    • P
                      pierrearchi26
                      Bonjour Fredo, je voulais savoir si il etait possible d'exporter/creer une scene depuis portrait studio avec uniquement l'objet selectionné et la camera choisie (fonctionnement different de l'outil bloque la camera et la visibilite de l'objet qui est temporaire et ne modifie pas la scene ) ? Pour pouvoir directement utiliser ces scènes dans Layout par la suite ... Gain de temps. Plugin top pour les nomenclatures et les notice de fabrication. Merci.
                      Dave RD 1 Reply Last reply
                        Dave R @pierrearchi26
                        @pierrearchi26 said:
                        So I can then use these scenes directly in Layout... Saves time.
                        I'm curious how this would save time. Can you explain? Show an example of how you use FredoPortrait for bills of materials and manufacturing instructions. It might help me with some of my work.
                        Maybe start a thread on this in the Tutorials category.
                        • fredo6F
                          FredoPortrait essentially generates images, not scenes. For isolating components and views, it uses temporary settings of the camera and object visibility, but this is transcient.
                          Generating scenes with isolated objects and specified cameras would be another plugin.
                          • 5 / 5
