    Medeek Stair
    3 Posts 1 Posters 41 Views 2 Watching
    • medeekM Offline
      medeek
      After some more fiddling with the code and some additional logic, here is an OTP rail with various fittings and various corner conditions:
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I will also be including a new series of hand rail fittings that is compatible with the LJ6000 handrail profile.
        design.medeek.com
        • medeekM Offline
          medeek
          I think I have the post algorithm mostly worked out now. The PTP posts use boolean subtraction against the hand rail since we can't be certain of their contact angle or if they are square, round or some other non-standard geometry (custom components).
          The problem with boolean subtraction is that if you are a dealing with a lot of rail segments and posts it can slow things up a bit. I may have to rethink this or have a way to disable the boolean subtraction for those who prefer performance over cosmetics.
          design.medeek.com
