<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Medeek Stair]]></title><description><![CDATA[<p dir="auto">After some more fiddling with the code and some additional logic, here is an OTP rail with various fittings and various corner conditions:</p>
<p dir="auto"><img src="/assets/uploads/files/1777864108203-stair_su017_800.jpg" alt="stair_su017_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1777864108227-stair_su018_800-resized.jpg" alt="stair_su018_800.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/164850/medeek-stair</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 03:08:13 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164850.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 May 2026 03:08:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Medeek Stair on Sat, 09 May 2026 07:42:44 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Version 4.5.2b</strong> - 05.09.2026</p>
<ul>
<li>Added the following (L.J. Smith) rosettes: LJ7037, LJ7027, LJ7026, LJ7033.</li>
<li>Fixed a floating point rounding error in the "Move Segment" tool.</li>
<li>Enabled handrailing fittings (ie. rosettes) for the start and end of a handrail when no post at these locations is selected.</li>
<li>Added a left and right half-post component into the newel post library.</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1778312543461-stair_su032_800.jpg" alt="stair_su032_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1778312543476-stair_su033_800.jpg" alt="stair_su033_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1778312543499-stair_su035_800.jpg" alt="stair_su035_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I tested out a half post because I've seen stair railings that terminate like the image below:</p>
<p dir="auto"><img src="/assets/uploads/files/1778312562559-stair_su034_800.jpg" alt="stair_su034_800.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1620574</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620574</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Sat, 09 May 2026 07:42:44 GMT</pubDate></item><item><title><![CDATA[Reply to Medeek Stair on Fri, 08 May 2026 23:30:06 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Tutorial 86</strong>: Stair Railing</p>
<p dir="auto"></p><div class="ratio ratio-16x9">
<iframe src="https://www.youtube-nocookie.com/embed/TqZTTJ2kkYE" title="YouTube video player" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share; fullscreen"></iframe>
</div><p></p>
]]></description><link>https://community.sketchucation.com/post/1620573</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620573</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Fri, 08 May 2026 23:30:06 GMT</pubDate></item><item><title><![CDATA[Reply to Medeek Stair on Fri, 08 May 2026 09:22:33 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Version 4.5.2</strong> - 05.08.2026</p>
<ul>
<li>Added the following tools to the Medeek Wall Stairs toolbar: Draw Railing, Edit Railing, Move Railing.</li>
<li>Enabled the railing tool/module, added railing type: balustrade (stair rail).</li>
<li>Added various handrail fittings (OTP) for the LJ6000 series handrail: M0209, M0219, M0220, M0211_L, M0211_R, M0211_135_L, M0211_135_R, M0221_L, M0221_R, M0221_135_L, M0221_135_R.</li>
<li>Added the following (L.J. Smith) shoerail profiles: LJ6000S, LJ6001S, LJ6006S, LJ6045S.</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1778232020821-m0221_l.png" alt="M0221_L.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1778232020826-wall_stairs_su_menu_active.jpg" alt="wall_stairs_su_menu_active.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is brand new so there will be few fires to put out and some fine tuning or maybe even a few additional parameters needed.  Send me your feedback.</p>
]]></description><link>https://community.sketchucation.com/post/1620563</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620563</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Fri, 08 May 2026 09:22:33 GMT</pubDate></item><item><title><![CDATA[Reply to Medeek Stair on Fri, 08 May 2026 06:16:26 GMT]]></title><description><![CDATA[<p dir="auto">I spent the better part of today trying to figure out ways to make the boolean subtraction more efficient.  In the end my best solution was to create a square "cutter" in place of the actual (ornate) post which does significantly help.</p>
<p dir="auto">However if the face count of the "cutting" post is under 100 then I just use the original post geometry.  I've noticed that some of these ornate posts can have over 400 faces or polycounts.</p>
<p dir="auto">Now I just need to do a few more checks and throw the kitchen sink at this thing:</p>
<p dir="auto"><img src="/assets/uploads/files/1778220984289-stair_su030_800.jpg" alt="stair_su030_800.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1620562</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620562</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Fri, 08 May 2026 06:16:26 GMT</pubDate></item><item><title><![CDATA[Reply to Medeek Stair on Thu, 07 May 2026 08:04:33 GMT]]></title><description><![CDATA[<p dir="auto">I've added in an an auto-clearance calculation for the balusters that are adjacent to posts so I think I have that mostly under control now but some additional logic may need to be added depending on feedback from everyone.</p>
<p dir="auto">Here is a first look at these various railings with shoerail added.</p>
<p dir="auto"><img src="/assets/uploads/files/1778141057621-stair_su025_800.jpg" alt="stair_su025_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1778141057646-stair_su026_800.jpg" alt="stair_su026_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1778141057660-stair_su027_800.jpg" alt="stair_su027_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1778141057674-stair_su028_800.jpg" alt="stair_su028_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">The offset option for each post position allows one to have the shoerail cut by the posts or rest underneath the posts.  I'm trying to make this as flexible as possible.  Also I created the four standard LJ Smith profiles beyond the very basic rectangular profile.</p>
<p dir="auto">Due to the fact that there is quite a bit of boolean subtraction that can happen with the interaction between the posts and the handrail/shoerail combo, regenerating a railing can take a while, especially if it is much more than about five or six segments.  I guess its a tradeoff between simplicity and ornate details.</p>
<p dir="auto">The only way to squeeze more performance out of the boolean subtraction is to convert it to a more low level C++ routine, I may consider that.</p>
]]></description><link>https://community.sketchucation.com/post/1620553</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620553</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Thu, 07 May 2026 08:04:33 GMT</pubDate></item><item><title><![CDATA[Reply to Medeek Stair on Tue, 05 May 2026 10:34:37 GMT]]></title><description><![CDATA[<p dir="auto">I think I have the post algorithm mostly worked out now.  The PTP posts use boolean subtraction against the hand rail since we can't be certain of their contact angle or if they are square, round or some other non-standard geometry (custom components).</p>
<p dir="auto">The problem with boolean subtraction is that if you are a dealing with a lot of rail segments and posts it can slow things up a bit.  I may have to rethink this or have a way to disable the boolean subtraction for those who prefer performance over cosmetics.</p>
<p dir="auto"><img src="/assets/uploads/files/1777977266535-stair_su020_800.jpg" alt="stair_su020_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1777977266551-stair_su021_800.jpg" alt="stair_su021_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1777977266566-stair_su022_800.jpg" alt="stair_su022_800.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1620511</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620511</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Tue, 05 May 2026 10:34:37 GMT</pubDate></item><item><title><![CDATA[Reply to Medeek Stair on Mon, 04 May 2026 08:21:19 GMT]]></title><description><![CDATA[<p dir="auto">I will also be including a new series of hand rail fittings that is compatible with the LJ6000 handrail profile.</p>
<p dir="auto"><img src="/assets/uploads/files/1777882871786-stair_su019_800.jpg" alt="stair_su019_800.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1777882871791-wall_stairs_su_menu_active.jpg" alt="wall_stairs_su_menu_active.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1620498</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620498</guid><dc:creator><![CDATA[medeek]]></dc:creator><pubDate>Mon, 04 May 2026 08:21:19 GMT</pubDate></item></channel></rss>
