Any Australians on this site ?
Hi Guys I have not been very active on this site as I have been unwell. As an Australian member of the Australian Armies engineer emergency response squadron I and others were exposed to a chemical called PFAS (the forever chemical) in industrial quantities. It is now known to cause many serious issues. I myself have had 3 cancers, 2 heart attacks. and a stroke amongst other conditions there is an E petition on the subject of PFAS exposure .I do not know how many Aussies are on this sight (besides Box) But I thought I would post a link to the Petition If you would consider signing it if you are an Australian citizen.
Stay strong, brother. Talk often as you can, PM's available.
It sounds worse than it is mate, I am able, and going on an extended holiday to Moscow and Thailand to do a bit of diving. All my ailments have been treated very well. I am expecting a large 6 figure compensation payout in 5 days. So could be a lot worse
For your service and 'injuries' received, you are more than due and hopefully that settlement will keep you well/safe.
That extended holiday, have a blast and make some good memories. -
That extended holiday, have a blast and make some good memories.Yes thanks mate whilst in Thailand it will be a test to see if i will retire there and will make a trip to da nang in Vietnam to see if that might work.
With your input, this post could be even better ๐
