    FredoCorner merging separate faces
    6 Posts 3 Posters 352 Views 3 Watching
    • E
      elaton
      I'm using FredoCorner to soften cabinet edges (for later rendering). Currently, my rails and stiles on cabinet doors are divided into separate faces for greater realism, but once I apply FredoCorner it merges these faces into one. I've tried different settings, including the Bevel, and always the same issue. Please let me know if I'm doing something wrong or if this is just a limitation of FredoCorner (if the latter, is it also a limitation of MindSight's Round Corner?).
      Thanks.
      • fredo6F
        It would help to have a model and the topology of faces.
        • E
          elaton
          @fredo6 See attached. Thanks.
          test cabinet.skp
            Make the rails and stiles components so the faces don't get merged.
            • E
              elaton
              That did work -- thank you. However, I was hoping for a faster technique, without having to model the rails and stiles separately (usually I just draw 4 lines on the face of the cabinet box so that materials can be oriented differently). If you know of any other solution let me know. Thanks.
                If you want realism the frame parts would need to be separate componets. If you aren't going to model that way, just draw in the edges after radiusing the frame.
