    I Think I've Finally Finished my Falkestraße Model...
    43 Posts 6 Posters 3.4k Views 6 Watching
    • Tim DanaherT Offline
      Tim Danaher
      BTW, how do you delete or edit individual replies..???
      Cheers,
      Tim
      http://vizarch.blogspot.com
        Click these dots and you should see an Edit option.
        Tim DanaherT 1 Reply Last reply Reply Quote 0
          Tim Danaher @Rich O Brien
          @Rich-O-Brien Rich – all I get is Bookmark, create Permalink or Share This Post when I click on the three dots… it seems to happen if a reply has something embedded in it… text-only replies give Delete options…
          Cheers,
          Tim
            Rich O Brien Moderator @Tim Danaher
            @Tim-Danaher
            So no edit option?
              Would seem to be a login issue, if I select the three dots in other people's posts, that is what I see whereas my posts have the edit option which makes sense.
                @Rich-O-Brien No. None now... As Mike says, I get what I would get if I were looking at someone else's posts... 'Bookmark', 'Create Permalink', 'Share This Post'.
                Cheers,
                Tim
                  Tim Danaher
                  This is on any post... I thought I saw and 'Edit' option on a text-only post last night, but it's not there, now...
                  Cheers,
                  Tim
                    I’ll take a look at settings to see.
                    Editing posts is a sensitive permission because it would allow malicious accounts to retroactively insert links to unwanted content to occur.
                    But I will look and see if there is something we can do.
                    Tim DanaherT 1 Reply Last reply Reply Quote 1
                      @Rich-O-Brien Thanks, Rich, much appreciated...
                      Cheers,
                      Tim
                        Tim Danaher
                        Logged out and logged back in again... still can't edit or delete my posts...
                        Cheers,
                        Tim
                          I had a look yesterday and again just now. Based on what I see you should be able to edit and/or delete posts.
                          The only way I could actually test it would be to log into your account. That's not something I want to do without consent.
                          So it's a mystery why at the moment you can't edit.
                            Tim Danaher
                            Ha.!! It's working, now... weird...
                            Cheers,
                            Tim
                              Tim Danaher
                              Well, I always told myself I didn't need to model the original building's stairwell... but I couldn't resist... First try using PBR materials: it's all looking a bit dark. I wonder when SU will support light sources..? I cannot get rid of the depth fighting at the top of the stairs....
                              Cheers,
                              Tim
                              • KrassK Offline
                                Krass
                                very good!
                                Krass
                                  Tim Danaher @jo-ke
                                  @jo-ke Wenn du ein Rendering von meinem Modell machen möchtest, gibt es ‘ne ältere Version im 3D Warehouse.. Nur zu!
                                  If you‘d like to do a rendering of my model, there‘s an earlier version of it in the 3D Warehouse… Have at it!
                                  Cheers,
                                  Tim
                                  • jo-keJ Offline
                                    jo-ke
                                    Wow. I will have a look....
                                    looks like a nice weekendwork....
                                    Danke schön
                                    http://www.zz7.de
                                    • 2 / 3
