    [Plugin] QuadFaceTools
    680 Posts 116 Posters 679.0k Views 116 Watching
    • alsomarA Offline
      alsomar Extension Creator
      I think I've figured out what is wrong with the OBJ files generated by the OBJ Exporter from QFT and why sometimes they don't work properly in other software such as RizomUV or Substance Painter.
      I have reported this issue on the GitHub page for QFT, but I believe it could be helpful to someone if I also post it here, especially since a solution to the problem is provided at the end of the post.
      I've been struggling with this issue for quite some time, but since I didn't fully understand what was happening, I couldn't provide useful feedback. Recently, however, I've been able to clearly identify the problem and even managed to resolve it using Meshlab, a free software to clean and improve 3D models.
      The Issue
      The OBJ files generated with the OBJ exporter from QuadFaceTools have duplicated faces in those quads that have been triangulated in SketchUp.
      When you open an OBJ file created with this exporter, software like Blender automatically resolves this issue. However, other software such as Substance Painter or RizomUV may struggle to handle these duplicates correctly.
      I believe this issue is the root cause of these issues:
      • https://github.com/thomthom/quadface-tools/issues/127
      • https://github.com/thomthom/quadface-tools/issues/124
      • https://github.com/thomthom/quadface-tools/issues/120
      Reproducing the Issue
      I created a simple SketchUp model with just two cubes:
      240622_skp_cubes
      Each cube have 24 quads. The triangulated one (on the left) is a component called 'cube_t', and the other one (on the right) is also a component called 'cube_q'. I exported them separately using the OBJ exporter from QFT to identify the problem, using the following settings:
      QFT_settings
      After exporting, I obtained these two files: cube_q.obj and cube_t.obj.
      Next, I used the free open-source software Meshlab to check the number of faces in each OBJ file. After opening Meshlab, navigate to File > Import Mesh and select cube_q.obj.
      For the first mesh ('0'), you can see there are 48 faces (24 front + 24 back), as expected. However, when I added cube_t.obj using File > Import Mesh, for the second mesh ('1'), there were 96 faces, TWICE (!) the expected number for the same number of quads.
      This issue causes Substance Painter to struggle with generating proper automated UVs, while RizomUV fails to correctly utilize OBJ files exported from QFT's OBJ exporter.
      Fixing these OBJ Files using Meshlab
      Until a potential solution is considered within QFT's OBJ exporter itself, here's a simple and practical solution using MeshLab:
      1. Select the problematic mesh from the Layer Dialog.
      2. Go to Filters > Cleaning and Repairing > Remove Duplicated Faces.
        Step 2 Screenshot
      3. After completing the previous step, verify that the number of faces in cube_t.obj is 48. If correct, proceed to File > Export Mesh and save the corrected file as new_cube_t.obj (or a similar name).
      If you try to open this corrected file in RizomUV or Substance Painter (using the auto-UV features), it should work smoothly.
      Alejandro Soriano Visuals · All my links
      panixiaP 1 Reply Last reply Reply Quote 0
      • panixiaP Offline
        panixia @alsomar
        @alsomar said in [Plugin] QuadFaceTools:
        Hi Alejandro, I have no problem at all in Substance with QFT obj files (I can even bake hipoly objs into low poly objs with no issue).
        BTW it's a known problem and has been there forever.
        There's also a problem with unwelded UV islands (the UV are in the right places but actually each quad has cuts/seams at all edges).
        I shared a few info and workarounds about this problem years ago, but unfortunately Thom is really busy and apparently doesn't have time to fix it for now, so we still have to use workarounds.
        @summerson1990 said: @pilou said: Why not export from Max only unwelded quads? (separated) I have found that it's probably best of all to export from max ...
        sketchucation (community.sketchucation.com)
        The workaround in 3dsMax I mentioned in that post is outdated.
        Now I just filter the selection for polygons with 3 sides (in the selection tab) and erase all of them.
        In some cases I also export from QFT to Blender and then export an FBX to 3dsMax.
        alsomarA 2 Replies Last reply Reply Quote 0
        • panixiaP panixia referenced this topic on
        • alsomarA Offline
          alsomar Extension Creator @panixia
          @panixia said in [Plugin] QuadFaceTools:
          It's not another problem; it's the same one. The triangulated quads in SketchUp are being exported with duplicated faces. These duplicated faces are the ones you see unwelded in RizomUV. Blender usually fixes this problem just by opening the OBJ files.
          • alsomarA Offline
            @panixia I made a fix for the OBJ export issue in QuadFace Tools and submitted a pull request to the main branch. You can find the RBZ file from my fork here:
            Release Version 1.0.0-1 (obj export fix) · alsomar/quadface-tools
            Suite of tools for manipulating quad faces in SketchUp. - Release Version 1.0.0-1 (obj export fix) · alsomar/quadface-tools
            GitHub (github.com)
            Hope it helps.
            panixiaP 1 Reply Last reply Reply Quote 1
            • panixiaP Offline
              panixia @alsomar
              @alsomar Thanks Alejandro, I'll try this as soon as possible.
              Where do you tested the fix?
              Rizom? 3dsMax?
              Which modules sre involved? The exporter_obj.rb only?
              I myself have a slightly "hacked" version of QFT (mainly to use png icons which are better on my laptop with Sketchup 2021 rather than the new svg ones) so I would probably prefer to merge only the strictly necessary modules.
              alsomarA 1 Reply Last reply Reply Quote 0
              • alsomarA Offline
                @panixia Tested with RizomUV and Substance Painter. Works fine on my side, no unwelded UV islands.
                The modified file is entities.rb. At the end of this file, there's a method called get_entity. You have to delete there these three lines (1729 - 1731):
                if add_to_cache && @types[ Sketchup::Face ][ entity ].nil?
                    cache_entity( quad )
                And replace them with this one:
                cache_entity( quad ) if add_to_cache
                Here's the full explanation why this works:
                https://github.com/thomthom/quadface-tools/pull/135
                panixiaP 2 Replies Last reply Reply Quote 0
                • panixiaP Offline
                  panixia @alsomar
                  @alsomar ok, I'm going to test it against Max (using a model which I'm sure gave me problems in the past), gimme a moment. 👍
                  • panixiaP Offline
                    panixia @alsomar
                    @alsomar the floating triangles are gone, but still a few normal welding issue and unwelded UVs.
                    • alsomarA Offline
                      @panixia You see the model unsmoothed in 3ds Max just because your SketchUp model has unsmoothed lines. Despite the SubD subdivisions making the surface look smooth, if you can see the edges it means the lines are actually unsmoothed. In this frame I can see all the lines:
                      A quick example to clarify my point. Same shape in SketchUp, with smoothed and unsmoothed lines:
                      This is how the exported obj look in Blender:
                      • panixiaP Offline
                        panixia @alsomar
                        Nope.
                        They are soft = false; smooth = true.
                        The smooth attribute is the one actually welding the normals/creating smoothing groups.
                        The soft is a Sketchup-thing only to separate "logical surfaces" which can be selected with a single click.
                        In the legacy version of the exporter, the generated obj from 3dsMax was seen as 2 overlapped meshes: one with the properly welded/smoothed quads (BUT unwelded UV seams between each quad, despite the individual quads being perfectly in place in the UV chart) + one made of floating/unwelded triangles.
                        In Blender the legacy exporter always worked fine (didn't test your fork against Blender, but I guess it could work fine).
                        Another weird/interesting thing is that the same objects, when exported straight out of WrapR work 100% fine.
                        • 30
                        • 31
                        • 32
                        • 33
                        • 34
                        • 34 / 34
